1 # Install script for directory: /home/paraview/VTK/ThirdParty/tiff
47  include("/home/paraview/build/VTK/ThirdParty/tiff/vtktiff/cmake_install.cmake")
48 endif()
49
50 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xlicensex" OR NOT CMAKE_INSTALL_COMPONENT)
51  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtktiff" TYPE FILE FILES "/home/paraview/VTK/ThirdParty/tiff/vtktiff/COPYRIGHT")
52 endif()
53
54 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
55  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES "/home/paraview/build/VTK/ThirdParty/tiff/vtk_tiff.h")
56 endif()
57
