1 # Install script for directory: /home/paraview/VTK/ThirdParty/png/vtkpng
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9/vtkpng" TYPE FILE FILES
47  "/home/paraview/VTK/ThirdParty/png/vtkpng/png.h"
48  "/home/paraview/VTK/ThirdParty/png/vtkpng/pngconf.h"
49  "/home/paraview/VTK/ThirdParty/png/vtkpng/pnglibconf.h"
50  "/home/paraview/VTK/ThirdParty/png/vtkpng/vtk_png_mangle.h"
51  )
52 endif()
53
54 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
55  foreach(file
56  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkpng-pv5.9.so.5.9"
57  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkpng-pv5.9.so.1"
58  )
59  if(EXISTS "${file}" AND
60  NOT IS_SYMLINK "${file}")
61  file(RPATH_CHECK
62  FILE "${file}"
63  RPATH "\$ORIGIN")
64  endif()
65  endforeach()
66  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
67  "/home/paraview/build/lib64/libvtkpng-pv5.9.so.5.9"
68  "/home/paraview/build/lib64/libvtkpng-pv5.9.so.1"
69  )
70  foreach(file
71  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkpng-pv5.9.so.5.9"
72  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkpng-pv5.9.so.1"
73  )
74  if(EXISTS "${file}" AND
75  NOT IS_SYMLINK "${file}")
76  file(RPATH_CHANGE
77  FILE "${file}"
78  OLD_RPATH "/home/paraview/build/lib64:"
79  NEW_RPATH "\$ORIGIN")
80  if(CMAKE_INSTALL_DO_STRIP)
81  execute_process(COMMAND "/usr/bin/strip" "${file}")
82  endif()
83  endif()
84  endforeach()
85 endif()
86
87 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
88  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkpng-pv5.9.so" AND
89  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkpng-pv5.9.so")
90  file(RPATH_CHECK
91  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkpng-pv5.9.so"
92  RPATH "\$ORIGIN")
93  endif()
94  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkpng-pv5.9.so")
95  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkpng-pv5.9.so" AND
96  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkpng-pv5.9.so")
97  file(RPATH_CHANGE
98  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkpng-pv5.9.so"
99  OLD_RPATH "/home/paraview/build/lib64:"
100  NEW_RPATH "\$ORIGIN")
101  if(CMAKE_INSTALL_DO_STRIP)
102  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkpng-pv5.9.so")
103  endif()
104  endif()
105 endif()
106
