1 # Install script for directory: /home/paraview/VTK/ThirdParty/mpi4py/vtkmpi4py/src
45 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/mpi4py" TYPE FILE FILES
47  "/home/paraview/build/lib64/python3.9/site-packages/mpi4py/__init__.py"
48  "/home/paraview/build/lib64/python3.9/site-packages/mpi4py/__init__.pxd"
49  "/home/paraview/build/lib64/python3.9/site-packages/mpi4py/MPI.pxd"
50  "/home/paraview/build/lib64/python3.9/site-packages/mpi4py/mpi.cfg"
51  )
52 endif()
53
54 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
55  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/mpi4py/MPI.so" AND
56  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/mpi4py/MPI.so")
57  file(RPATH_CHECK
58  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/mpi4py/MPI.so"
59  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
60  endif()
61  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/mpi4py" TYPE MODULE FILES "/home/paraview/build/lib64/python3.9/site-packages/mpi4py/MPI.so")
62  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/mpi4py/MPI.so" AND
63  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/mpi4py/MPI.so")
64  file(RPATH_CHANGE
65  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/mpi4py/MPI.so"
66  OLD_RPATH "/usr/lib64/openmpi/lib:/home/paraview/build/lib64:"
67  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
68  if(CMAKE_INSTALL_DO_STRIP)
69  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/mpi4py/MPI.so")
70  endif()
71  endif()
72 endif()
73
74 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
75  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9/vtkmpi4py/mpi4py" TYPE DIRECTORY FILES "/home/paraview/VTK/ThirdParty/mpi4py/vtkmpi4py/src/mpi4py/include/mpi4py/")
76 endif()
77
