1 # Install script for directory: /home/paraview/VTK/ThirdParty/lzma/vtklzma
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9/vtklzma/src/liblzma/api" TYPE FILE FILES
47  "/home/paraview/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma.h"
48  "/home/paraview/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/base.h"
49  "/home/paraview/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/bcj.h"
50  "/home/paraview/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/block.h"
51  "/home/paraview/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/check.h"
52  "/home/paraview/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/container.h"
53  "/home/paraview/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/delta.h"
54  "/home/paraview/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/filter.h"
55  "/home/paraview/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/hardware.h"
56  "/home/paraview/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/index.h"
57  "/home/paraview/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/index_hash.h"
58  "/home/paraview/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/lzma12.h"
59  "/home/paraview/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/stream_flags.h"
60  "/home/paraview/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/version.h"
61  "/home/paraview/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma/vli.h"
62  "/home/paraview/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/vtk_lzma_mangle.h"
63  )
64 endif()
65
66 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
67  foreach(file
68  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.9.so.5.9"
69  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.9.so.1"
70  )
71  if(EXISTS "${file}" AND
72  NOT IS_SYMLINK "${file}")
73  file(RPATH_CHECK
74  FILE "${file}"
75  RPATH "\$ORIGIN")
76  endif()
77  endforeach()
78  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
79  "/home/paraview/build/lib64/libvtklzma-pv5.9.so.5.9"
80  "/home/paraview/build/lib64/libvtklzma-pv5.9.so.1"
81  )
82  foreach(file
83  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.9.so.5.9"
84  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.9.so.1"
85  )
86  if(EXISTS "${file}" AND
87  NOT IS_SYMLINK "${file}")
88  file(RPATH_CHANGE
89  FILE "${file}"
90  OLD_RPATH ":::::::"
91  NEW_RPATH "\$ORIGIN")
92  if(CMAKE_INSTALL_DO_STRIP)
93  execute_process(COMMAND "/usr/bin/strip" "${file}")
94  endif()
95  endif()
96  endforeach()
97 endif()
98
99 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
100  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.9.so" AND
101  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.9.so")
102  file(RPATH_CHECK
103  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.9.so"
104  RPATH "\$ORIGIN")
105  endif()
106  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtklzma-pv5.9.so")
107  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.9.so" AND
108  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.9.so")
109  file(RPATH_CHANGE
110  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.9.so"
111  OLD_RPATH ":::::::"
112  NEW_RPATH "\$ORIGIN")
113  if(CMAKE_INSTALL_DO_STRIP)
114  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklzma-pv5.9.so")
115  endif()
116  endif()
117 endif()
118
119 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
120  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9/vtklzma/src/liblzma/api" TYPE DIRECTORY FILES "/home/paraview/VTK/ThirdParty/lzma/vtklzma/src/liblzma/api/lzma")
121 endif()
122
