cmake_clean.cmake
1 file(REMOVE_RECURSE
2  "../../../../lib64/libvtklzma-pv5.9.pdb"
3  "../../../../lib64/libvtklzma-pv5.9.so"
4  "../../../../lib64/libvtklzma-pv5.9.so.1"
5  "../../../../lib64/libvtklzma-pv5.9.so.5.9"
6  "CMakeFiles/lzma.dir/src/common/tuklib_cpucores.c.o"
7  "CMakeFiles/lzma.dir/src/common/tuklib_physmem.c.o"
8  "CMakeFiles/lzma.dir/src/liblzma/check/check.c.o"
9  "CMakeFiles/lzma.dir/src/liblzma/check/crc32_fast.c.o"
10  "CMakeFiles/lzma.dir/src/liblzma/check/crc32_table.c.o"
11  "CMakeFiles/lzma.dir/src/liblzma/check/crc64_fast.c.o"
12  "CMakeFiles/lzma.dir/src/liblzma/check/crc64_table.c.o"
13  "CMakeFiles/lzma.dir/src/liblzma/check/sha256.c.o"
14  "CMakeFiles/lzma.dir/src/liblzma/common/alone_decoder.c.o"
15  "CMakeFiles/lzma.dir/src/liblzma/common/alone_encoder.c.o"
16  "CMakeFiles/lzma.dir/src/liblzma/common/auto_decoder.c.o"
17  "CMakeFiles/lzma.dir/src/liblzma/common/block_buffer_decoder.c.o"
18  "CMakeFiles/lzma.dir/src/liblzma/common/block_buffer_encoder.c.o"
19  "CMakeFiles/lzma.dir/src/liblzma/common/block_decoder.c.o"
20  "CMakeFiles/lzma.dir/src/liblzma/common/block_encoder.c.o"
21  "CMakeFiles/lzma.dir/src/liblzma/common/block_header_decoder.c.o"
22  "CMakeFiles/lzma.dir/src/liblzma/common/block_header_encoder.c.o"
23  "CMakeFiles/lzma.dir/src/liblzma/common/block_util.c.o"
24  "CMakeFiles/lzma.dir/src/liblzma/common/common.c.o"
25  "CMakeFiles/lzma.dir/src/liblzma/common/easy_buffer_encoder.c.o"
26  "CMakeFiles/lzma.dir/src/liblzma/common/easy_decoder_memusage.c.o"
27  "CMakeFiles/lzma.dir/src/liblzma/common/easy_encoder.c.o"
28  "CMakeFiles/lzma.dir/src/liblzma/common/easy_encoder_memusage.c.o"
29  "CMakeFiles/lzma.dir/src/liblzma/common/easy_preset.c.o"
30  "CMakeFiles/lzma.dir/src/liblzma/common/filter_buffer_decoder.c.o"
31  "CMakeFiles/lzma.dir/src/liblzma/common/filter_buffer_encoder.c.o"
32  "CMakeFiles/lzma.dir/src/liblzma/common/filter_common.c.o"
33  "CMakeFiles/lzma.dir/src/liblzma/common/filter_decoder.c.o"
34  "CMakeFiles/lzma.dir/src/liblzma/common/filter_encoder.c.o"
35  "CMakeFiles/lzma.dir/src/liblzma/common/filter_flags_decoder.c.o"
36  "CMakeFiles/lzma.dir/src/liblzma/common/filter_flags_encoder.c.o"
37  "CMakeFiles/lzma.dir/src/liblzma/common/hardware_cputhreads.c.o"
38  "CMakeFiles/lzma.dir/src/liblzma/common/hardware_physmem.c.o"
39  "CMakeFiles/lzma.dir/src/liblzma/common/index.c.o"
40  "CMakeFiles/lzma.dir/src/liblzma/common/index_decoder.c.o"
41  "CMakeFiles/lzma.dir/src/liblzma/common/index_encoder.c.o"
42  "CMakeFiles/lzma.dir/src/liblzma/common/index_hash.c.o"
43  "CMakeFiles/lzma.dir/src/liblzma/common/outqueue.c.o"
44  "CMakeFiles/lzma.dir/src/liblzma/common/stream_buffer_decoder.c.o"
45  "CMakeFiles/lzma.dir/src/liblzma/common/stream_buffer_encoder.c.o"
46  "CMakeFiles/lzma.dir/src/liblzma/common/stream_decoder.c.o"
47  "CMakeFiles/lzma.dir/src/liblzma/common/stream_encoder.c.o"
48  "CMakeFiles/lzma.dir/src/liblzma/common/stream_encoder_mt.c.o"
49  "CMakeFiles/lzma.dir/src/liblzma/common/stream_flags_common.c.o"
50  "CMakeFiles/lzma.dir/src/liblzma/common/stream_flags_decoder.c.o"
51  "CMakeFiles/lzma.dir/src/liblzma/common/stream_flags_encoder.c.o"
52  "CMakeFiles/lzma.dir/src/liblzma/common/vli_decoder.c.o"
53  "CMakeFiles/lzma.dir/src/liblzma/common/vli_encoder.c.o"
54  "CMakeFiles/lzma.dir/src/liblzma/common/vli_size.c.o"
55  "CMakeFiles/lzma.dir/src/liblzma/delta/delta_common.c.o"
56  "CMakeFiles/lzma.dir/src/liblzma/delta/delta_decoder.c.o"
57  "CMakeFiles/lzma.dir/src/liblzma/delta/delta_encoder.c.o"
58  "CMakeFiles/lzma.dir/src/liblzma/lz/lz_decoder.c.o"
59  "CMakeFiles/lzma.dir/src/liblzma/lz/lz_encoder.c.o"
60  "CMakeFiles/lzma.dir/src/liblzma/lz/lz_encoder_mf.c.o"
61  "CMakeFiles/lzma.dir/src/liblzma/lzma/fastpos_table.c.o"
62  "CMakeFiles/lzma.dir/src/liblzma/lzma/lzma2_decoder.c.o"
63  "CMakeFiles/lzma.dir/src/liblzma/lzma/lzma2_encoder.c.o"
64  "CMakeFiles/lzma.dir/src/liblzma/lzma/lzma_decoder.c.o"
65  "CMakeFiles/lzma.dir/src/liblzma/lzma/lzma_encoder.c.o"
66  "CMakeFiles/lzma.dir/src/liblzma/lzma/lzma_encoder_optimum_fast.c.o"
67  "CMakeFiles/lzma.dir/src/liblzma/lzma/lzma_encoder_optimum_normal.c.o"
68  "CMakeFiles/lzma.dir/src/liblzma/lzma/lzma_encoder_presets.c.o"
69  "CMakeFiles/lzma.dir/src/liblzma/rangecoder/price_table.c.o"
70  "CMakeFiles/lzma.dir/src/liblzma/simple/arm.c.o"
71  "CMakeFiles/lzma.dir/src/liblzma/simple/armthumb.c.o"
72  "CMakeFiles/lzma.dir/src/liblzma/simple/ia64.c.o"
73  "CMakeFiles/lzma.dir/src/liblzma/simple/powerpc.c.o"
74  "CMakeFiles/lzma.dir/src/liblzma/simple/simple_coder.c.o"
75  "CMakeFiles/lzma.dir/src/liblzma/simple/simple_decoder.c.o"
76  "CMakeFiles/lzma.dir/src/liblzma/simple/simple_encoder.c.o"
77  "CMakeFiles/lzma.dir/src/liblzma/simple/sparc.c.o"
78  "CMakeFiles/lzma.dir/src/liblzma/simple/x86.c.o"
79 )
80
81 # Per-language clean rules from dependency scanning.
82 foreach(lang C)
83  include(CMakeFiles/lzma.dir/cmake_clean_${lang}.cmake OPTIONAL)
84 endforeach()
