1 # Install script for directory: /home/paraview/VTK/ThirdParty/loguru/vtkloguru 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9/vtkloguru" TYPE FILE FILES
47 "/home/paraview/VTK/ThirdParty/loguru/vtkloguru/loguru.hpp" 48 "/home/paraview/build/VTK/ThirdParty/loguru/vtkloguru/vtkloguru_export.h" 52 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 54 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkloguru-pv5.9.so.5.9
" 55 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkloguru-pv5.9.so.1
" 57 if(EXISTS "${file}
" AND 58 NOT IS_SYMLINK "${file}
") 64 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 65 "/home/paraview/build/lib64/libvtkloguru-pv5.9.so.5.9
" 66 "/home/paraview/build/lib64/libvtkloguru-pv5.9.so.1
" 69 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkloguru-pv5.9.so.5.9
" 70 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkloguru-pv5.9.so.1
" 72 if(EXISTS "${file}
" AND 73 NOT IS_SYMLINK "${file}
") 78 if(CMAKE_INSTALL_DO_STRIP) 79 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 85 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 86 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkloguru-pv5.9.so
" AND 87 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkloguru-pv5.9.so
") 89 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkloguru-pv5.9.so
" 92 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkloguru-pv5.9.so
") 93 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkloguru-pv5.9.so
" AND 94 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkloguru-pv5.9.so
") 96 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkloguru-pv5.9.so
" 99 if(CMAKE_INSTALL_DO_STRIP) 100 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkloguru-pv5.9.so
