1 # Install script for directory: /home/paraview/VTK/ThirdParty/libxml2/vtklibxml2 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9/vtklibxml2/include/libxml" TYPE FILE FILES
47 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/c14n.h" 48 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/catalog.h" 49 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/chvalid.h" 50 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/debugXML.h" 51 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/dict.h" 52 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/DOCBparser.h" 53 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/encoding.h" 54 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/entities.h" 55 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/globals.h" 56 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/hash.h" 57 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/HTMLparser.h" 58 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/HTMLtree.h" 59 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/list.h" 60 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/nanoftp.h" 61 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/nanohttp.h" 62 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/parser.h" 63 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/parserInternals.h" 64 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/pattern.h" 65 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/relaxng.h" 66 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/SAX.h" 67 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/SAX2.h" 68 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/schemasInternals.h" 69 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/schematron.h" 70 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/threads.h" 71 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/tree.h" 72 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/uri.h" 73 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/valid.h" 74 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/vtk_libxml2_mangle.h" 75 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xinclude.h" 76 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xlink.h" 77 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlautomata.h" 78 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlerror.h" 79 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlexports.h" 80 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlIO.h" 81 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlmemory.h" 82 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlmodule.h" 83 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlreader.h" 84 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlregexp.h" 85 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlsave.h" 86 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlschemas.h" 87 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlschemastypes.h" 88 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlstring.h" 89 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlunicode.h" 90 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlwin32version.h" 91 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlwriter.h" 92 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xpath.h" 93 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xpathInternals.h" 94 "/home/paraview/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xpointer.h" 95 "/home/paraview/build/VTK/ThirdParty/libxml2/vtklibxml2/include/libxml/xmlversion.h" 99 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 101 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.9.so.5.9
" 102 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.9.so.1
" 104 if(EXISTS "${file}
" AND 105 NOT IS_SYMLINK "${file}
") 111 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 112 "/home/paraview/build/lib64/libvtklibxml2-pv5.9.so.5.9
" 113 "/home/paraview/build/lib64/libvtklibxml2-pv5.9.so.1
" 116 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.9.so.5.9
" 117 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.9.so.1
" 119 if(EXISTS "${file}
" AND 120 NOT IS_SYMLINK "${file}
") 123 OLD_RPATH "/home/paraview/build/lib64:
" 124 NEW_RPATH "\$ORIGIN
") 125 if(CMAKE_INSTALL_DO_STRIP) 126 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 132 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 133 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.9.so
" AND 134 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.9.so
") 136 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.9.so
" 139 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtklibxml2-pv5.9.so
") 140 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.9.so
" AND 141 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.9.so
") 143 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.9.so
" 144 OLD_RPATH "/home/paraview/build/lib64:
" 145 NEW_RPATH "\$ORIGIN
") 146 if(CMAKE_INSTALL_DO_STRIP) 147 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtklibxml2-pv5.9.so
