1 # Install script for directory: /home/paraview/VTK/ThirdParty/jpeg/vtkjpeg
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9/vtkjpeg" TYPE FILE FILES
47  "/home/paraview/VTK/ThirdParty/jpeg/vtkjpeg/jerror.h"
48  "/home/paraview/VTK/ThirdParty/jpeg/vtkjpeg/jmorecfg.h"
49  "/home/paraview/VTK/ThirdParty/jpeg/vtkjpeg/jpeglib.h"
50  "/home/paraview/VTK/ThirdParty/jpeg/vtkjpeg/vtk_jpeg_mangle.h"
51  "/home/paraview/build/VTK/ThirdParty/jpeg/vtkjpeg/jconfig.h"
52  )
53 endif()
54
55 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
56  foreach(file
57  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.9.so.5.9"
58  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.9.so.1"
59  )
60  if(EXISTS "${file}" AND
61  NOT IS_SYMLINK "${file}")
62  file(RPATH_CHECK
63  FILE "${file}"
64  RPATH "\$ORIGIN")
65  endif()
66  endforeach()
67  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
68  "/home/paraview/build/lib64/libvtkjpeg-pv5.9.so.5.9"
69  "/home/paraview/build/lib64/libvtkjpeg-pv5.9.so.1"
70  )
71  foreach(file
72  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.9.so.5.9"
73  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.9.so.1"
74  )
75  if(EXISTS "${file}" AND
76  NOT IS_SYMLINK "${file}")
77  file(RPATH_CHANGE
78  FILE "${file}"
79  OLD_RPATH ":::::::"
80  NEW_RPATH "\$ORIGIN")
81  if(CMAKE_INSTALL_DO_STRIP)
82  execute_process(COMMAND "/usr/bin/strip" "${file}")
83  endif()
84  endif()
85  endforeach()
86 endif()
87
88 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
89  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.9.so" AND
90  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.9.so")
91  file(RPATH_CHECK
92  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.9.so"
93  RPATH "\$ORIGIN")
94  endif()
95  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkjpeg-pv5.9.so")
96  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.9.so" AND
97  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.9.so")
98  file(RPATH_CHANGE
99  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.9.so"
100  OLD_RPATH ":::::::"
101  NEW_RPATH "\$ORIGIN")
102  if(CMAKE_INSTALL_DO_STRIP)
103  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkjpeg-pv5.9.so")
104  endif()
105  endif()
106 endif()
107
