1 # Install script for directory: /home/paraview/VTK/ThirdParty/doubleconversion/vtkdoubleconversion 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9/vtkdoubleconversion" TYPE FILE FILES
47 "/home/paraview/VTK/ThirdParty/doubleconversion/vtkdoubleconversion/double-conversion/bignum.h" 48 "/home/paraview/VTK/ThirdParty/doubleconversion/vtkdoubleconversion/double-conversion/cached-powers.h" 49 "/home/paraview/VTK/ThirdParty/doubleconversion/vtkdoubleconversion/double-conversion/diy-fp.h" 50 "/home/paraview/VTK/ThirdParty/doubleconversion/vtkdoubleconversion/double-conversion/double-conversion.h" 51 "/home/paraview/VTK/ThirdParty/doubleconversion/vtkdoubleconversion/double-conversion/fast-dtoa.h" 52 "/home/paraview/VTK/ThirdParty/doubleconversion/vtkdoubleconversion/double-conversion/fixed-dtoa.h" 53 "/home/paraview/VTK/ThirdParty/doubleconversion/vtkdoubleconversion/double-conversion/ieee.h" 54 "/home/paraview/VTK/ThirdParty/doubleconversion/vtkdoubleconversion/double-conversion/strtod.h" 55 "/home/paraview/VTK/ThirdParty/doubleconversion/vtkdoubleconversion/double-conversion/utils.h" 56 "/home/paraview/build/VTK/ThirdParty/doubleconversion/vtkdoubleconversion/vtkdoubleconversion_export.h" 60 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 62 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.9.so.5.9
" 63 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.9.so.1
" 65 if(EXISTS "${file}
") 72 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 73 "/home/paraview/build/lib64/libvtkdoubleconversion-pv5.9.so.5.9
" 74 "/home/paraview/build/lib64/libvtkdoubleconversion-pv5.9.so.1
" 77 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.9.so.5.9
" 78 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.9.so.1
" 80 if(EXISTS "${file}
" AND 81 NOT IS_SYMLINK "${file}
") 86 if(CMAKE_INSTALL_DO_STRIP) 87 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 93 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 94 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.9.so
" AND 95 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.9.so
") 97 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.9.so
" 100 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkdoubleconversion-pv5.9.so
") 101 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.9.so
" AND 102 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.9.so
") 104 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.9.so
" 106 NEW_RPATH "\$ORIGIN
") 107 if(CMAKE_INSTALL_DO_STRIP) 108 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkdoubleconversion-pv5.9.so
