1 # Install script for directory: /home/paraview/VTK/ThirdParty/doubleconversion 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
"/home/paraview/build/VTK/ThirdParty/doubleconversion/vtkdoubleconversion/cmake_install.cmake")
50 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xlicensex
" OR NOT CMAKE_INSTALL_COMPONENT) 51 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkdoubleconversion
" TYPE FILE FILES 52 "/home/paraview/VTK/ThirdParty/doubleconversion/vtkdoubleconversion/COPYING
" 53 "/home/paraview/VTK/ThirdParty/doubleconversion/vtkdoubleconversion/LICENSE
" 57 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 58 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9
" TYPE FILE FILES "/home/paraview/build/VTK/ThirdParty/doubleconversion/vtk_doubleconversion.h
