1 # Install script for directory: /home/paraview/VTK/Rendering/Volume 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47 "/home/paraview/VTK/Rendering/Volume/vtkDirectionEncoder.h" 48 "/home/paraview/VTK/Rendering/Volume/vtkEncodedGradientEstimator.h" 49 "/home/paraview/VTK/Rendering/Volume/vtkEncodedGradientShader.h" 50 "/home/paraview/VTK/Rendering/Volume/vtkFiniteDifferenceGradientEstimator.h" 51 "/home/paraview/VTK/Rendering/Volume/vtkFixedPointRayCastImage.h" 52 "/home/paraview/VTK/Rendering/Volume/vtkFixedPointVolumeRayCastCompositeGOHelper.h" 53 "/home/paraview/VTK/Rendering/Volume/vtkFixedPointVolumeRayCastCompositeGOShadeHelper.h" 54 "/home/paraview/VTK/Rendering/Volume/vtkFixedPointVolumeRayCastCompositeHelper.h" 55 "/home/paraview/VTK/Rendering/Volume/vtkFixedPointVolumeRayCastCompositeShadeHelper.h" 56 "/home/paraview/VTK/Rendering/Volume/vtkFixedPointVolumeRayCastHelper.h" 57 "/home/paraview/VTK/Rendering/Volume/vtkFixedPointVolumeRayCastMapper.h" 58 "/home/paraview/VTK/Rendering/Volume/vtkFixedPointVolumeRayCastMIPHelper.h" 59 "/home/paraview/VTK/Rendering/Volume/vtkGPUVolumeRayCastMapper.h" 60 "/home/paraview/VTK/Rendering/Volume/vtkMultiVolume.h" 61 "/home/paraview/VTK/Rendering/Volume/vtkOSPRayVolumeInterface.h" 62 "/home/paraview/VTK/Rendering/Volume/vtkProjectedTetrahedraMapper.h" 63 "/home/paraview/VTK/Rendering/Volume/vtkRayCastImageDisplayHelper.h" 64 "/home/paraview/VTK/Rendering/Volume/vtkRecursiveSphereDirectionEncoder.h" 65 "/home/paraview/VTK/Rendering/Volume/vtkSphericalDirectionEncoder.h" 66 "/home/paraview/VTK/Rendering/Volume/vtkUnstructuredGridBunykRayCastFunction.h" 67 "/home/paraview/VTK/Rendering/Volume/vtkUnstructuredGridHomogeneousRayIntegrator.h" 68 "/home/paraview/VTK/Rendering/Volume/vtkUnstructuredGridLinearRayIntegrator.h" 69 "/home/paraview/VTK/Rendering/Volume/vtkUnstructuredGridPartialPreIntegration.h" 70 "/home/paraview/VTK/Rendering/Volume/vtkUnstructuredGridPreIntegration.h" 71 "/home/paraview/VTK/Rendering/Volume/vtkUnstructuredGridVolumeMapper.h" 72 "/home/paraview/VTK/Rendering/Volume/vtkUnstructuredGridVolumeRayCastFunction.h" 73 "/home/paraview/VTK/Rendering/Volume/vtkUnstructuredGridVolumeRayCastIterator.h" 74 "/home/paraview/VTK/Rendering/Volume/vtkUnstructuredGridVolumeRayCastMapper.h" 75 "/home/paraview/VTK/Rendering/Volume/vtkUnstructuredGridVolumeRayIntegrator.h" 76 "/home/paraview/VTK/Rendering/Volume/vtkUnstructuredGridVolumeZSweepMapper.h" 77 "/home/paraview/VTK/Rendering/Volume/vtkVolumeMapper.h" 78 "/home/paraview/VTK/Rendering/Volume/vtkVolumeOutlineSource.h" 79 "/home/paraview/VTK/Rendering/Volume/vtkVolumePicker.h" 80 "/home/paraview/VTK/Rendering/Volume/vtkVolumeRayCastSpaceLeapingImageFilter.h" 81 "/home/paraview/build/VTK/Rendering/Volume/vtkRenderingVolumeModule.h" 85 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 86 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkRenderingVolume-hierarchy.txt
" FILES "/home/paraview/build/lib64/
vtk/hierarchy/ParaView/vtkRenderingVolume-hierarchy.txt
") 89 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 91 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.9.so.5.9
" 92 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.9.so.1
" 94 if(EXISTS "${file}
" AND 95 NOT IS_SYMLINK "${file}
") 101 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 102 "/home/paraview/build/lib64/libvtkRenderingVolume-pv5.9.so.5.9
" 103 "/home/paraview/build/lib64/libvtkRenderingVolume-pv5.9.so.1
" 106 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.9.so.5.9
" 107 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.9.so.1
" 109 if(EXISTS "${file}
" AND 110 NOT IS_SYMLINK "${file}
") 113 OLD_RPATH "/home/paraview/build/lib64:
" 114 NEW_RPATH "\$ORIGIN
") 115 if(CMAKE_INSTALL_DO_STRIP) 116 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 122 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 123 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.9.so
" AND 124 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.9.so
") 126 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.9.so
" 129 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkRenderingVolume-pv5.9.so
") 130 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.9.so
" AND 131 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.9.so
") 133 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.9.so
" 134 OLD_RPATH "/home/paraview/build/lib64:
" 135 NEW_RPATH "\$ORIGIN
") 136 if(CMAKE_INSTALL_DO_STRIP) 137 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingVolume-pv5.9.so
