1 # Install script for directory: /home/paraview/VTK/Parallel/MPI
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47  "/home/paraview/VTK/Parallel/MPI/vtkMPI.h"
48  "/home/paraview/VTK/Parallel/MPI/vtkMPICommunicator.h"
49  "/home/paraview/VTK/Parallel/MPI/vtkMPIController.h"
50  "/home/paraview/VTK/Parallel/MPI/vtkMPIUtilities.h"
51  "/home/paraview/build/VTK/Parallel/MPI/vtkParallelMPIModule.h"
52  )
53 endif()
54
55 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
56  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkParallelMPI-hierarchy.txt" FILES "/home/paraview/build/lib64/vtk/hierarchy/ParaView/vtkParallelMPI-hierarchy.txt")
57 endif()
58
59 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
60  foreach(file
61  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelMPI-pv5.9.so.5.9"
62  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelMPI-pv5.9.so.1"
63  )
64  if(EXISTS "${file}" AND
65  NOT IS_SYMLINK "${file}")
66  file(RPATH_CHECK
67  FILE "${file}"
68  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
69  endif()
70  endforeach()
71  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
72  "/home/paraview/build/lib64/libvtkParallelMPI-pv5.9.so.5.9"
73  "/home/paraview/build/lib64/libvtkParallelMPI-pv5.9.so.1"
74  )
75  foreach(file
76  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelMPI-pv5.9.so.5.9"
77  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelMPI-pv5.9.so.1"
78  )
79  if(EXISTS "${file}" AND
80  NOT IS_SYMLINK "${file}")
81  file(RPATH_CHANGE
82  FILE "${file}"
83  OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:"
84  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
85  if(CMAKE_INSTALL_DO_STRIP)
86  execute_process(COMMAND "/usr/bin/strip" "${file}")
87  endif()
88  endif()
89  endforeach()
90 endif()
91
92 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
93  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelMPI-pv5.9.so" AND
94  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelMPI-pv5.9.so")
95  file(RPATH_CHECK
96  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelMPI-pv5.9.so"
97  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
98  endif()
99  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkParallelMPI-pv5.9.so")
100  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelMPI-pv5.9.so" AND
101  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelMPI-pv5.9.so")
102  file(RPATH_CHANGE
103  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelMPI-pv5.9.so"
104  OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:"
105  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
106  if(CMAKE_INSTALL_DO_STRIP)
107  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelMPI-pv5.9.so")
108  endif()
109  endif()
110 endif()
111
