1 # Install script for directory: /home/paraview/VTK/Parallel/DIY 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47 "/home/paraview/VTK/Parallel/DIY/vtkDIYDataExchanger.h" 48 "/home/paraview/VTK/Parallel/DIY/vtkDIYUtilities.h" 49 "/home/paraview/VTK/Parallel/DIY/vtkDIYExplicitAssigner.h" 50 "/home/paraview/build/VTK/Parallel/DIY/vtkParallelDIYModule.h" 54 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 56 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelDIY-pv5.9.so.5.9
" 57 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelDIY-pv5.9.so.1
" 59 if(EXISTS "${file}
" AND 60 NOT IS_SYMLINK "${file}
") 63 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 66 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 67 "/home/paraview/build/lib64/libvtkParallelDIY-pv5.9.so.5.9
" 68 "/home/paraview/build/lib64/libvtkParallelDIY-pv5.9.so.1
" 71 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelDIY-pv5.9.so.5.9
" 72 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelDIY-pv5.9.so.1
" 74 if(EXISTS "${file}
" AND 75 NOT IS_SYMLINK "${file}
") 78 OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:
" 79 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 80 if(CMAKE_INSTALL_DO_STRIP) 81 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 87 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 88 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelDIY-pv5.9.so
" AND 89 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelDIY-pv5.9.so
") 91 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelDIY-pv5.9.so
" 92 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 94 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkParallelDIY-pv5.9.so
") 95 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelDIY-pv5.9.so
" AND 96 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelDIY-pv5.9.so
") 98 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelDIY-pv5.9.so
" 99 OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:
" 100 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 101 if(CMAKE_INSTALL_DO_STRIP) 102 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkParallelDIY-pv5.9.so
