1 # Install script for directory: /home/paraview/VTK/Infovis/Core
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47  "/home/paraview/VTK/Infovis/Core/vtkAddMembershipArray.h"
48  "/home/paraview/VTK/Infovis/Core/vtkAdjacencyMatrixToEdgeTable.h"
49  "/home/paraview/VTK/Infovis/Core/vtkArrayNorm.h"
50  "/home/paraview/VTK/Infovis/Core/vtkArrayToTable.h"
51  "/home/paraview/VTK/Infovis/Core/vtkCollapseGraph.h"
52  "/home/paraview/VTK/Infovis/Core/vtkCollapseVerticesByArray.h"
53  "/home/paraview/VTK/Infovis/Core/vtkContinuousScatterplot.h"
54  "/home/paraview/VTK/Infovis/Core/vtkDataObjectToTable.h"
55  "/home/paraview/VTK/Infovis/Core/vtkDotProductSimilarity.h"
56  "/home/paraview/VTK/Infovis/Core/vtkEdgeCenters.h"
57  "/home/paraview/VTK/Infovis/Core/vtkExpandSelectedGraph.h"
58  "/home/paraview/VTK/Infovis/Core/vtkExtractSelectedGraph.h"
59  "/home/paraview/VTK/Infovis/Core/vtkExtractSelectedTree.h"
60  "/home/paraview/VTK/Infovis/Core/vtkGenerateIndexArray.h"
61  "/home/paraview/VTK/Infovis/Core/vtkGraphHierarchicalBundleEdges.h"
62  "/home/paraview/VTK/Infovis/Core/vtkGroupLeafVertices.h"
63  "/home/paraview/VTK/Infovis/Core/vtkKCoreDecomposition.h"
64  "/home/paraview/VTK/Infovis/Core/vtkMergeColumns.h"
65  "/home/paraview/VTK/Infovis/Core/vtkMergeGraphs.h"
66  "/home/paraview/VTK/Infovis/Core/vtkMergeTables.h"
67  "/home/paraview/VTK/Infovis/Core/vtkMutableGraphHelper.h"
68  "/home/paraview/VTK/Infovis/Core/vtkNetworkHierarchy.h"
69  "/home/paraview/VTK/Infovis/Core/vtkPipelineGraphSource.h"
70  "/home/paraview/VTK/Infovis/Core/vtkPruneTreeFilter.h"
71  "/home/paraview/VTK/Infovis/Core/vtkRandomGraphSource.h"
72  "/home/paraview/VTK/Infovis/Core/vtkReduceTable.h"
73  "/home/paraview/VTK/Infovis/Core/vtkRemoveHiddenData.h"
74  "/home/paraview/VTK/Infovis/Core/vtkRemoveIsolatedVertices.h"
75  "/home/paraview/VTK/Infovis/Core/vtkSparseArrayToTable.h"
76  "/home/paraview/VTK/Infovis/Core/vtkStreamGraph.h"
77  "/home/paraview/VTK/Infovis/Core/vtkStringToCategory.h"
78  "/home/paraview/VTK/Infovis/Core/vtkStringToNumeric.h"
79  "/home/paraview/VTK/Infovis/Core/vtkTableToArray.h"
80  "/home/paraview/VTK/Infovis/Core/vtkTableToGraph.h"
81  "/home/paraview/VTK/Infovis/Core/vtkTableToSparseArray.h"
82  "/home/paraview/VTK/Infovis/Core/vtkTableToTreeFilter.h"
83  "/home/paraview/VTK/Infovis/Core/vtkThresholdGraph.h"
84  "/home/paraview/VTK/Infovis/Core/vtkThresholdTable.h"
85  "/home/paraview/VTK/Infovis/Core/vtkTransferAttributes.h"
86  "/home/paraview/VTK/Infovis/Core/vtkTransposeMatrix.h"
87  "/home/paraview/VTK/Infovis/Core/vtkTreeDifferenceFilter.h"
88  "/home/paraview/VTK/Infovis/Core/vtkTreeFieldAggregator.h"
89  "/home/paraview/VTK/Infovis/Core/vtkTreeLevelsFilter.h"
90  "/home/paraview/VTK/Infovis/Core/vtkVertexDegree.h"
91  "/home/paraview/VTK/Infovis/Core/vtkWordCloud.h"
92  "/home/paraview/build/VTK/Infovis/Core/vtkInfovisCoreModule.h"
93  )
94 endif()
95
96 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
97  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkInfovisCore-hierarchy.txt" FILES "/home/paraview/build/lib64/vtk/hierarchy/ParaView/vtkInfovisCore-hierarchy.txt")
98 endif()
99
100 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
101  foreach(file
102  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.9.so.5.9"
103  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.9.so.1"
104  )
105  if(EXISTS "${file}" AND
106  NOT IS_SYMLINK "${file}")
107  file(RPATH_CHECK
108  FILE "${file}"
109  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
110  endif()
111  endforeach()
112  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
113  "/home/paraview/build/lib64/libvtkInfovisCore-pv5.9.so.5.9"
114  "/home/paraview/build/lib64/libvtkInfovisCore-pv5.9.so.1"
115  )
116  foreach(file
117  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.9.so.5.9"
118  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.9.so.1"
119  )
120  if(EXISTS "${file}" AND
121  NOT IS_SYMLINK "${file}")
122  file(RPATH_CHANGE
123  FILE "${file}"
124  OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:"
125  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
126  if(CMAKE_INSTALL_DO_STRIP)
127  execute_process(COMMAND "/usr/bin/strip" "${file}")
128  endif()
129  endif()
130  endforeach()
131 endif()
132
133 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
134  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.9.so" AND
135  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.9.so")
136  file(RPATH_CHECK
137  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.9.so"
138  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
139  endif()
140  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkInfovisCore-pv5.9.so")
141  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.9.so" AND
142  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.9.so")
143  file(RPATH_CHANGE
144  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.9.so"
145  OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:"
146  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
147  if(CMAKE_INSTALL_DO_STRIP)
148  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkInfovisCore-pv5.9.so")
149  endif()
150  endif()
151 endif()
152
