1 # Install script for directory: /home/paraview/VTK/Imaging/Hybrid
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47  "/home/paraview/VTK/Imaging/Hybrid/vtkBooleanTexture.h"
48  "/home/paraview/VTK/Imaging/Hybrid/vtkCheckerboardSplatter.h"
49  "/home/paraview/VTK/Imaging/Hybrid/vtkFastSplatter.h"
50  "/home/paraview/VTK/Imaging/Hybrid/vtkGaussianSplatter.h"
51  "/home/paraview/VTK/Imaging/Hybrid/vtkImageCursor3D.h"
52  "/home/paraview/VTK/Imaging/Hybrid/vtkImageRectilinearWipe.h"
53  "/home/paraview/VTK/Imaging/Hybrid/vtkImageToPoints.h"
54  "/home/paraview/VTK/Imaging/Hybrid/vtkPointLoad.h"
55  "/home/paraview/VTK/Imaging/Hybrid/vtkSampleFunction.h"
56  "/home/paraview/VTK/Imaging/Hybrid/vtkShepardMethod.h"
57  "/home/paraview/VTK/Imaging/Hybrid/vtkSliceCubes.h"
58  "/home/paraview/VTK/Imaging/Hybrid/vtkSurfaceReconstructionFilter.h"
59  "/home/paraview/VTK/Imaging/Hybrid/vtkTriangularTexture.h"
60  "/home/paraview/VTK/Imaging/Hybrid/vtkVoxelModeller.h"
61  "/home/paraview/build/VTK/Imaging/Hybrid/vtkImagingHybridModule.h"
62  )
63 endif()
64
65 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
66  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkImagingHybrid-hierarchy.txt" FILES "/home/paraview/build/lib64/vtk/hierarchy/ParaView/vtkImagingHybrid-hierarchy.txt")
67 endif()
68
69 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
70  foreach(file
71  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingHybrid-pv5.9.so.5.9"
72  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingHybrid-pv5.9.so.1"
73  )
74  if(EXISTS "${file}" AND
75  NOT IS_SYMLINK "${file}")
76  file(RPATH_CHECK
77  FILE "${file}"
78  RPATH "\$ORIGIN")
79  endif()
80  endforeach()
81  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
82  "/home/paraview/build/lib64/libvtkImagingHybrid-pv5.9.so.5.9"
83  "/home/paraview/build/lib64/libvtkImagingHybrid-pv5.9.so.1"
84  )
85  foreach(file
86  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingHybrid-pv5.9.so.5.9"
87  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingHybrid-pv5.9.so.1"
88  )
89  if(EXISTS "${file}" AND
90  NOT IS_SYMLINK "${file}")
91  file(RPATH_CHANGE
92  FILE "${file}"
93  OLD_RPATH "/home/paraview/build/lib64:"
94  NEW_RPATH "\$ORIGIN")
96  execute_process(COMMAND "/usr/bin/strip" "${file}")
97  endif()
98  endif()
99  endforeach()
100 endif()
101
102 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
103  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingHybrid-pv5.9.so" AND
104  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingHybrid-pv5.9.so")
105  file(RPATH_CHECK
106  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingHybrid-pv5.9.so"
107  RPATH "\$ORIGIN")
108  endif()
109  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkImagingHybrid-pv5.9.so")
110  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingHybrid-pv5.9.so" AND
111  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingHybrid-pv5.9.so")
112  file(RPATH_CHANGE
113  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingHybrid-pv5.9.so"
114  OLD_RPATH "/home/paraview/build/lib64:"
115  NEW_RPATH "\$ORIGIN")
116  if(CMAKE_INSTALL_DO_STRIP)
117  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingHybrid-pv5.9.so")
118  endif()
119  endif()
120 endif()
121
