1 # Install script for directory: /home/paraview/VTK/Imaging/General
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47  "/home/paraview/VTK/Imaging/General/vtkImageAnisotropicDiffusion2D.h"
48  "/home/paraview/VTK/Imaging/General/vtkImageAnisotropicDiffusion3D.h"
49  "/home/paraview/VTK/Imaging/General/vtkImageCheckerboard.h"
50  "/home/paraview/VTK/Imaging/General/vtkImageCityBlockDistance.h"
51  "/home/paraview/VTK/Imaging/General/vtkImageConvolve.h"
52  "/home/paraview/VTK/Imaging/General/vtkImageCorrelation.h"
53  "/home/paraview/VTK/Imaging/General/vtkImageEuclideanDistance.h"
54  "/home/paraview/VTK/Imaging/General/vtkImageEuclideanToPolar.h"
55  "/home/paraview/VTK/Imaging/General/vtkImageGaussianSmooth.h"
56  "/home/paraview/VTK/Imaging/General/vtkImageGradient.h"
57  "/home/paraview/VTK/Imaging/General/vtkImageGradientMagnitude.h"
58  "/home/paraview/VTK/Imaging/General/vtkImageHybridMedian2D.h"
59  "/home/paraview/VTK/Imaging/General/vtkImageLaplacian.h"
60  "/home/paraview/VTK/Imaging/General/vtkImageMedian3D.h"
61  "/home/paraview/VTK/Imaging/General/vtkImageNormalize.h"
62  "/home/paraview/VTK/Imaging/General/vtkImageRange3D.h"
63  "/home/paraview/VTK/Imaging/General/vtkImageSeparableConvolution.h"
64  "/home/paraview/VTK/Imaging/General/vtkImageSobel2D.h"
65  "/home/paraview/VTK/Imaging/General/vtkImageSobel3D.h"
66  "/home/paraview/VTK/Imaging/General/vtkImageSpatialAlgorithm.h"
67  "/home/paraview/VTK/Imaging/General/vtkImageVariance3D.h"
68  "/home/paraview/VTK/Imaging/General/vtkSimpleImageFilterExample.h"
69  "/home/paraview/VTK/Imaging/General/vtkImageSlab.h"
70  "/home/paraview/VTK/Imaging/General/vtkImageSlabReslice.h"
71  "/home/paraview/build/VTK/Imaging/General/vtkImagingGeneralModule.h"
72  )
73 endif()
74
75 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
76  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkImagingGeneral-hierarchy.txt" FILES "/home/paraview/build/lib64/vtk/hierarchy/ParaView/vtkImagingGeneral-hierarchy.txt")
77 endif()
78
79 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
80  foreach(file
81  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.9.so.5.9"
82  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.9.so.1"
83  )
84  if(EXISTS "${file}" AND
85  NOT IS_SYMLINK "${file}")
86  file(RPATH_CHECK
87  FILE "${file}"
88  RPATH "\$ORIGIN")
89  endif()
90  endforeach()
91  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
92  "/home/paraview/build/lib64/libvtkImagingGeneral-pv5.9.so.5.9"
93  "/home/paraview/build/lib64/libvtkImagingGeneral-pv5.9.so.1"
94  )
95  foreach(file
96  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.9.so.5.9"
97  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.9.so.1"
98  )
99  if(EXISTS "${file}" AND
100  NOT IS_SYMLINK "${file}")
101  file(RPATH_CHANGE
102  FILE "${file}"
103  OLD_RPATH "/home/paraview/build/lib64:"
104  NEW_RPATH "\$ORIGIN")
105  if(CMAKE_INSTALL_DO_STRIP)
106  execute_process(COMMAND "/usr/bin/strip" "${file}")
107  endif()
108  endif()
109  endforeach()
110 endif()
111
112 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
113  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.9.so" AND
114  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.9.so")
115  file(RPATH_CHECK
116  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.9.so"
117  RPATH "\$ORIGIN")
118  endif()
119  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkImagingGeneral-pv5.9.so")
120  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.9.so" AND
121  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.9.so")
122  file(RPATH_CHANGE
123  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.9.so"
124  OLD_RPATH "/home/paraview/build/lib64:"
125  NEW_RPATH "\$ORIGIN")
126  if(CMAKE_INSTALL_DO_STRIP)
127  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkImagingGeneral-pv5.9.so")
128  endif()
129  endif()
130 endif()
131
