1 # Install script for directory: /home/paraview/VTK/IO/XML
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47  "/home/paraview/VTK/IO/XML/vtkRTXMLPolyDataReader.h"
48  "/home/paraview/VTK/IO/XML/vtkXMLCompositeDataReader.h"
49  "/home/paraview/VTK/IO/XML/vtkXMLCompositeDataWriter.h"
50  "/home/paraview/VTK/IO/XML/vtkXMLDataObjectWriter.h"
51  "/home/paraview/VTK/IO/XML/vtkXMLDataReader.h"
52  "/home/paraview/VTK/IO/XML/vtkXMLDataSetWriter.h"
53  "/home/paraview/VTK/IO/XML/vtkXMLFileReadTester.h"
54  "/home/paraview/VTK/IO/XML/vtkXMLGenericDataObjectReader.h"
55  "/home/paraview/VTK/IO/XML/vtkXMLHierarchicalBoxDataFileConverter.h"
56  "/home/paraview/VTK/IO/XML/vtkXMLHierarchicalBoxDataReader.h"
57  "/home/paraview/VTK/IO/XML/vtkXMLHierarchicalBoxDataWriter.h"
58  "/home/paraview/VTK/IO/XML/vtkXMLHierarchicalDataReader.h"
59  "/home/paraview/VTK/IO/XML/vtkXMLHyperTreeGridReader.h"
60  "/home/paraview/VTK/IO/XML/vtkXMLHyperTreeGridWriter.h"
61  "/home/paraview/VTK/IO/XML/vtkXMLImageDataReader.h"
62  "/home/paraview/VTK/IO/XML/vtkXMLImageDataWriter.h"
63  "/home/paraview/VTK/IO/XML/vtkXMLMultiBlockDataReader.h"
64  "/home/paraview/VTK/IO/XML/vtkXMLMultiBlockDataWriter.h"
65  "/home/paraview/VTK/IO/XML/vtkXMLMultiGroupDataReader.h"
66  "/home/paraview/VTK/IO/XML/vtkXMLPDataObjectReader.h"
67  "/home/paraview/VTK/IO/XML/vtkXMLPDataReader.h"
68  "/home/paraview/VTK/IO/XML/vtkXMLPHyperTreeGridReader.h"
69  "/home/paraview/VTK/IO/XML/vtkXMLPImageDataReader.h"
70  "/home/paraview/VTK/IO/XML/vtkXMLPPolyDataReader.h"
71  "/home/paraview/VTK/IO/XML/vtkXMLPRectilinearGridReader.h"
72  "/home/paraview/VTK/IO/XML/vtkXMLPStructuredDataReader.h"
73  "/home/paraview/VTK/IO/XML/vtkXMLPStructuredGridReader.h"
74  "/home/paraview/VTK/IO/XML/vtkXMLPTableReader.h"
75  "/home/paraview/VTK/IO/XML/vtkXMLPUnstructuredDataReader.h"
76  "/home/paraview/VTK/IO/XML/vtkXMLPUnstructuredGridReader.h"
77  "/home/paraview/VTK/IO/XML/vtkXMLPartitionedDataSetCollectionReader.h"
78  "/home/paraview/VTK/IO/XML/vtkXMLPartitionedDataSetCollectionWriter.h"
79  "/home/paraview/VTK/IO/XML/vtkXMLPartitionedDataSetReader.h"
80  "/home/paraview/VTK/IO/XML/vtkXMLPartitionedDataSetWriter.h"
81  "/home/paraview/VTK/IO/XML/vtkXMLPolyDataReader.h"
82  "/home/paraview/VTK/IO/XML/vtkXMLPolyDataWriter.h"
83  "/home/paraview/VTK/IO/XML/vtkXMLReader.h"
84  "/home/paraview/VTK/IO/XML/vtkXMLRectilinearGridReader.h"
85  "/home/paraview/VTK/IO/XML/vtkXMLRectilinearGridWriter.h"
86  "/home/paraview/VTK/IO/XML/vtkXMLStructuredDataReader.h"
87  "/home/paraview/VTK/IO/XML/vtkXMLStructuredDataWriter.h"
88  "/home/paraview/VTK/IO/XML/vtkXMLStructuredGridReader.h"
89  "/home/paraview/VTK/IO/XML/vtkXMLStructuredGridWriter.h"
90  "/home/paraview/VTK/IO/XML/vtkXMLTableReader.h"
91  "/home/paraview/VTK/IO/XML/vtkXMLTableWriter.h"
92  "/home/paraview/VTK/IO/XML/vtkXMLUniformGridAMRReader.h"
93  "/home/paraview/VTK/IO/XML/vtkXMLUniformGridAMRWriter.h"
94  "/home/paraview/VTK/IO/XML/vtkXMLUnstructuredDataReader.h"
95  "/home/paraview/VTK/IO/XML/vtkXMLUnstructuredDataWriter.h"
96  "/home/paraview/VTK/IO/XML/vtkXMLUnstructuredGridReader.h"
97  "/home/paraview/VTK/IO/XML/vtkXMLUnstructuredGridWriter.h"
98  "/home/paraview/VTK/IO/XML/vtkXMLWriter.h"
99  "/home/paraview/VTK/IO/XML/vtkXMLWriterC.h"
100  "/home/paraview/build/VTK/IO/XML/vtkIOXMLModule.h"
101  )
102 endif()
103
104 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
105  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkIOXML-hierarchy.txt" FILES "/home/paraview/build/lib64/vtk/hierarchy/ParaView/vtkIOXML-hierarchy.txt")
106 endif()
107
108 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
109  foreach(file
110  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOXML-pv5.9.so.5.9"
111  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOXML-pv5.9.so.1"
112  )
113  if(EXISTS "${file}" AND
114  NOT IS_SYMLINK "${file}")
115  file(RPATH_CHECK
116  FILE "${file}"
117  RPATH "\$ORIGIN")
118  endif()
119  endforeach()
120  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
121  "/home/paraview/build/lib64/libvtkIOXML-pv5.9.so.5.9"
122  "/home/paraview/build/lib64/libvtkIOXML-pv5.9.so.1"
123  )
124  foreach(file
125  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOXML-pv5.9.so.5.9"
126  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOXML-pv5.9.so.1"
127  )
128  if(EXISTS "${file}" AND
129  NOT IS_SYMLINK "${file}")
130  file(RPATH_CHANGE
131  FILE "${file}"
132  OLD_RPATH "/home/paraview/build/lib64:"
133  NEW_RPATH "\$ORIGIN")
134  if(CMAKE_INSTALL_DO_STRIP)
135  execute_process(COMMAND "/usr/bin/strip" "${file}")
136  endif()
137  endif()
138  endforeach()
139 endif()
140
141 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
142  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOXML-pv5.9.so" AND
143  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOXML-pv5.9.so")
144  file(RPATH_CHECK
145  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOXML-pv5.9.so"
146  RPATH "\$ORIGIN")
147  endif()
148  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkIOXML-pv5.9.so")
149  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOXML-pv5.9.so" AND
150  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOXML-pv5.9.so")
151  file(RPATH_CHANGE
152  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOXML-pv5.9.so"
153  OLD_RPATH "/home/paraview/build/lib64:"
154  NEW_RPATH "\$ORIGIN")
155  if(CMAKE_INSTALL_DO_STRIP)
156  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOXML-pv5.9.so")
157  endif()
158  endif()
159 endif()
160
