1 # Install script for directory: /home/paraview/VTK/IO/Parallel
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47  "/home/paraview/VTK/IO/Parallel/vtkEnSightWriter.h"
48  "/home/paraview/VTK/IO/Parallel/vtkMultiBlockPLOT3DReader.h"
49  "/home/paraview/VTK/IO/Parallel/vtkPlot3DMetaReader.h"
50  "/home/paraview/VTK/IO/Parallel/vtkPChacoReader.h"
51  "/home/paraview/VTK/IO/Parallel/vtkPDataSetReader.h"
52  "/home/paraview/VTK/IO/Parallel/vtkPDataSetWriter.h"
53  "/home/paraview/VTK/IO/Parallel/vtkPImageWriter.h"
54  "/home/paraview/VTK/IO/Parallel/vtkPOpenFOAMReader.h"
55  "/home/paraview/build/VTK/IO/Parallel/vtkIOParallelModule.h"
56  )
57 endif()
58
59 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
60  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkIOParallel-hierarchy.txt" FILES "/home/paraview/build/lib64/vtk/hierarchy/ParaView/vtkIOParallel-hierarchy.txt")
61 endif()
62
63 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
64  foreach(file
65  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallel-pv5.9.so.5.9"
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallel-pv5.9.so.1"
67  )
68  if(EXISTS "${file}" AND
69  NOT IS_SYMLINK "${file}")
70  file(RPATH_CHECK
71  FILE "${file}"
72  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
73  endif()
74  endforeach()
75  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
76  "/home/paraview/build/lib64/libvtkIOParallel-pv5.9.so.5.9"
77  "/home/paraview/build/lib64/libvtkIOParallel-pv5.9.so.1"
78  )
79  foreach(file
80  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallel-pv5.9.so.5.9"
81  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallel-pv5.9.so.1"
82  )
83  if(EXISTS "${file}" AND
84  NOT IS_SYMLINK "${file}")
85  file(RPATH_CHANGE
86  FILE "${file}"
87  OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:"
88  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
89  if(CMAKE_INSTALL_DO_STRIP)
90  execute_process(COMMAND "/usr/bin/strip" "${file}")
91  endif()
92  endif()
93  endforeach()
94 endif()
95
96 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
97  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallel-pv5.9.so" AND
98  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallel-pv5.9.so")
99  file(RPATH_CHECK
100  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallel-pv5.9.so"
101  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
102  endif()
103  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkIOParallel-pv5.9.so")
104  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallel-pv5.9.so" AND
105  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallel-pv5.9.so")
106  file(RPATH_CHANGE
107  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallel-pv5.9.so"
108  OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:"
109  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
110  if(CMAKE_INSTALL_DO_STRIP)
111  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallel-pv5.9.so")
112  endif()
113  endif()
114 endif()
115
