1 # Install script for directory: /home/paraview/VTK/IO/ParallelXML
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47  "/home/paraview/VTK/IO/ParallelXML/vtkXMLPDataSetWriter.h"
48  "/home/paraview/VTK/IO/ParallelXML/vtkXMLPDataObjectWriter.h"
49  "/home/paraview/VTK/IO/ParallelXML/vtkXMLPDataWriter.h"
50  "/home/paraview/VTK/IO/ParallelXML/vtkXMLPImageDataWriter.h"
51  "/home/paraview/VTK/IO/ParallelXML/vtkXMLPPartitionedDataSetWriter.h"
52  "/home/paraview/VTK/IO/ParallelXML/vtkXMLPPolyDataWriter.h"
53  "/home/paraview/VTK/IO/ParallelXML/vtkXMLPRectilinearGridWriter.h"
54  "/home/paraview/VTK/IO/ParallelXML/vtkXMLPStructuredDataWriter.h"
55  "/home/paraview/VTK/IO/ParallelXML/vtkXMLPStructuredGridWriter.h"
56  "/home/paraview/VTK/IO/ParallelXML/vtkXMLPTableWriter.h"
57  "/home/paraview/VTK/IO/ParallelXML/vtkXMLPUnstructuredDataWriter.h"
58  "/home/paraview/VTK/IO/ParallelXML/vtkXMLPUnstructuredGridWriter.h"
59  "/home/paraview/VTK/IO/ParallelXML/vtkXMLPHierarchicalBoxDataWriter.h"
60  "/home/paraview/VTK/IO/ParallelXML/vtkXMLPMultiBlockDataWriter.h"
61  "/home/paraview/VTK/IO/ParallelXML/vtkXMLPUniformGridAMRWriter.h"
62  "/home/paraview/VTK/IO/ParallelXML/vtkXMLPHyperTreeGridWriter.h"
63  "/home/paraview/build/VTK/IO/ParallelXML/vtkIOParallelXMLModule.h"
64  )
65 endif()
66
67 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
68  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkIOParallelXML-hierarchy.txt" FILES "/home/paraview/build/lib64/vtk/hierarchy/ParaView/vtkIOParallelXML-hierarchy.txt")
69 endif()
70
71 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
72  foreach(file
73  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv5.9.so.5.9"
74  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv5.9.so.1"
75  )
76  if(EXISTS "${file}" AND
77  NOT IS_SYMLINK "${file}")
78  file(RPATH_CHECK
79  FILE "${file}"
80  RPATH "\$ORIGIN")
81  endif()
82  endforeach()
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
84  "/home/paraview/build/lib64/libvtkIOParallelXML-pv5.9.so.5.9"
85  "/home/paraview/build/lib64/libvtkIOParallelXML-pv5.9.so.1"
86  )
87  foreach(file
88  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv5.9.so.5.9"
89  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv5.9.so.1"
90  )
91  if(EXISTS "${file}" AND
92  NOT IS_SYMLINK "${file}")
93  file(RPATH_CHANGE
94  FILE "${file}"
95  OLD_RPATH "/home/paraview/build/lib64:"
96  NEW_RPATH "\$ORIGIN")
97  if(CMAKE_INSTALL_DO_STRIP)
98  execute_process(COMMAND "/usr/bin/strip" "${file}")
99  endif()
100  endif()
101  endforeach()
102 endif()
103
104 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
105  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv5.9.so" AND
106  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv5.9.so")
107  file(RPATH_CHECK
108  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv5.9.so"
109  RPATH "\$ORIGIN")
110  endif()
111  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkIOParallelXML-pv5.9.so")
112  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv5.9.so" AND
113  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv5.9.so")
114  file(RPATH_CHANGE
115  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv5.9.so"
116  OLD_RPATH "/home/paraview/build/lib64:"
117  NEW_RPATH "\$ORIGIN")
118  if(CMAKE_INSTALL_DO_STRIP)
119  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelXML-pv5.9.so")
120  endif()
121  endif()
122 endif()
123
