1 # Install script for directory: /home/paraview/VTK/IO/Legacy 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47 "/home/paraview/VTK/IO/Legacy/vtkCompositeDataReader.h" 48 "/home/paraview/VTK/IO/Legacy/vtkCompositeDataWriter.h" 49 "/home/paraview/VTK/IO/Legacy/vtkDataObjectReader.h" 50 "/home/paraview/VTK/IO/Legacy/vtkDataObjectWriter.h" 51 "/home/paraview/VTK/IO/Legacy/vtkDataReader.h" 52 "/home/paraview/VTK/IO/Legacy/vtkDataSetReader.h" 53 "/home/paraview/VTK/IO/Legacy/vtkDataSetWriter.h" 54 "/home/paraview/VTK/IO/Legacy/vtkDataWriter.h" 55 "/home/paraview/VTK/IO/Legacy/vtkGenericDataObjectReader.h" 56 "/home/paraview/VTK/IO/Legacy/vtkGenericDataObjectWriter.h" 57 "/home/paraview/VTK/IO/Legacy/vtkGraphReader.h" 58 "/home/paraview/VTK/IO/Legacy/vtkGraphWriter.h" 59 "/home/paraview/VTK/IO/Legacy/vtkPixelExtentIO.h" 60 "/home/paraview/VTK/IO/Legacy/vtkPolyDataReader.h" 61 "/home/paraview/VTK/IO/Legacy/vtkPolyDataWriter.h" 62 "/home/paraview/VTK/IO/Legacy/vtkRectilinearGridReader.h" 63 "/home/paraview/VTK/IO/Legacy/vtkRectilinearGridWriter.h" 64 "/home/paraview/VTK/IO/Legacy/vtkSimplePointsReader.h" 65 "/home/paraview/VTK/IO/Legacy/vtkSimplePointsWriter.h" 66 "/home/paraview/VTK/IO/Legacy/vtkStructuredGridReader.h" 67 "/home/paraview/VTK/IO/Legacy/vtkStructuredGridWriter.h" 68 "/home/paraview/VTK/IO/Legacy/vtkStructuredPointsReader.h" 69 "/home/paraview/VTK/IO/Legacy/vtkStructuredPointsWriter.h" 70 "/home/paraview/VTK/IO/Legacy/vtkTableReader.h" 71 "/home/paraview/VTK/IO/Legacy/vtkTableWriter.h" 72 "/home/paraview/VTK/IO/Legacy/vtkTreeReader.h" 73 "/home/paraview/VTK/IO/Legacy/vtkTreeWriter.h" 74 "/home/paraview/VTK/IO/Legacy/vtkUnstructuredGridReader.h" 75 "/home/paraview/VTK/IO/Legacy/vtkUnstructuredGridWriter.h" 76 "/home/paraview/build/VTK/IO/Legacy/vtkIOLegacyModule.h" 80 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 81 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkIOLegacy-hierarchy.txt
" FILES "/home/paraview/build/lib64/
vtk/hierarchy/ParaView/vtkIOLegacy-hierarchy.txt
") 84 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 86 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.9.so.5.9
" 87 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.9.so.1
" 89 if(EXISTS "${file}
" AND 90 NOT IS_SYMLINK "${file}
") 96 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 97 "/home/paraview/build/lib64/libvtkIOLegacy-pv5.9.so.5.9
" 98 "/home/paraview/build/lib64/libvtkIOLegacy-pv5.9.so.1
" 101 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.9.so.5.9
" 102 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.9.so.1
" 104 if(EXISTS "${file}
" AND 105 NOT IS_SYMLINK "${file}
") 108 OLD_RPATH "/home/paraview/build/lib64:
" 109 NEW_RPATH "\$ORIGIN
") 110 if(CMAKE_INSTALL_DO_STRIP) 111 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 117 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 118 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.9.so
" AND 119 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.9.so
") 121 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.9.so
" 124 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkIOLegacy-pv5.9.so
") 125 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.9.so
" AND 126 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.9.so
") 128 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.9.so
" 129 OLD_RPATH "/home/paraview/build/lib64:
" 130 NEW_RPATH "\$ORIGIN
") 131 if(CMAKE_INSTALL_DO_STRIP) 132 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOLegacy-pv5.9.so
