1 # Install script for directory: /home/paraview/VTK/IO/Infovis 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47 "/home/paraview/VTK/IO/Infovis/vtkBiomTableReader.h" 48 "/home/paraview/VTK/IO/Infovis/vtkChacoGraphReader.h" 49 "/home/paraview/VTK/IO/Infovis/vtkDelimitedTextReader.h" 50 "/home/paraview/VTK/IO/Infovis/vtkDIMACSGraphReader.h" 51 "/home/paraview/VTK/IO/Infovis/vtkDIMACSGraphWriter.h" 52 "/home/paraview/VTK/IO/Infovis/vtkFixedWidthTextReader.h" 53 "/home/paraview/VTK/IO/Infovis/vtkISIReader.h" 54 "/home/paraview/VTK/IO/Infovis/vtkMultiNewickTreeReader.h" 55 "/home/paraview/VTK/IO/Infovis/vtkNewickTreeReader.h" 56 "/home/paraview/VTK/IO/Infovis/vtkNewickTreeWriter.h" 57 "/home/paraview/VTK/IO/Infovis/vtkPhyloXMLTreeReader.h" 58 "/home/paraview/VTK/IO/Infovis/vtkPhyloXMLTreeWriter.h" 59 "/home/paraview/VTK/IO/Infovis/vtkRISReader.h" 60 "/home/paraview/VTK/IO/Infovis/vtkTemporalDelimitedTextReader.h" 61 "/home/paraview/VTK/IO/Infovis/vtkTulipReader.h" 62 "/home/paraview/VTK/IO/Infovis/vtkXGMLReader.h" 63 "/home/paraview/VTK/IO/Infovis/vtkXMLTreeReader.h" 64 "/home/paraview/build/VTK/IO/Infovis/vtkIOInfovisModule.h" 68 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 69 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkIOInfovis-hierarchy.txt
" FILES "/home/paraview/build/lib64/
vtk/hierarchy/ParaView/vtkIOInfovis-hierarchy.txt
") 72 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 74 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOInfovis-pv5.9.so.5.9
" 75 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOInfovis-pv5.9.so.1
" 77 if(EXISTS "${file}
" AND 78 NOT IS_SYMLINK "${file}
") 81 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 84 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 85 "/home/paraview/build/lib64/libvtkIOInfovis-pv5.9.so.5.9
" 86 "/home/paraview/build/lib64/libvtkIOInfovis-pv5.9.so.1
" 89 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOInfovis-pv5.9.so.5.9
" 90 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOInfovis-pv5.9.so.1
" 92 if(EXISTS "${file}
" AND 93 NOT IS_SYMLINK "${file}
") 96 OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:
" 97 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 98 if(CMAKE_INSTALL_DO_STRIP) 99 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 105 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 106 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOInfovis-pv5.9.so
" AND 107 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOInfovis-pv5.9.so
") 109 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOInfovis-pv5.9.so
" 110 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 112 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkIOInfovis-pv5.9.so
") 113 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOInfovis-pv5.9.so
" AND 114 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOInfovis-pv5.9.so
") 116 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOInfovis-pv5.9.so
" 117 OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:
" 118 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 119 if(CMAKE_INSTALL_DO_STRIP) 120 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOInfovis-pv5.9.so
