1 # Install script for directory: /home/paraview/VTK/IO/Geometry
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47  "/home/paraview/VTK/IO/Geometry/vtkAVSucdReader.h"
48  "/home/paraview/VTK/IO/Geometry/vtkBYUReader.h"
49  "/home/paraview/VTK/IO/Geometry/vtkBYUWriter.h"
50  "/home/paraview/VTK/IO/Geometry/vtkChacoReader.h"
51  "/home/paraview/VTK/IO/Geometry/vtkFacetWriter.h"
52  "/home/paraview/VTK/IO/Geometry/vtkFLUENTReader.h"
53  "/home/paraview/VTK/IO/Geometry/vtkGAMBITReader.h"
54  "/home/paraview/VTK/IO/Geometry/vtkGaussianCubeReader.h"
55  "/home/paraview/VTK/IO/Geometry/vtkGLTFDocumentLoader.h"
56  "/home/paraview/VTK/IO/Geometry/vtkGLTFReader.h"
57  "/home/paraview/VTK/IO/Geometry/vtkHoudiniPolyDataWriter.h"
58  "/home/paraview/VTK/IO/Geometry/vtkIVWriter.h"
59  "/home/paraview/VTK/IO/Geometry/vtkMCubesReader.h"
60  "/home/paraview/VTK/IO/Geometry/vtkMCubesWriter.h"
61  "/home/paraview/VTK/IO/Geometry/vtkMFIXReader.h"
62  "/home/paraview/VTK/IO/Geometry/vtkMoleculeReaderBase.h"
63  "/home/paraview/VTK/IO/Geometry/vtkOBJReader.h"
64  "/home/paraview/VTK/IO/Geometry/vtkOBJWriter.h"
65  "/home/paraview/VTK/IO/Geometry/vtkOpenFOAMReader.h"
66  "/home/paraview/VTK/IO/Geometry/vtkParticleReader.h"
67  "/home/paraview/VTK/IO/Geometry/vtkPDBReader.h"
68  "/home/paraview/VTK/IO/Geometry/vtkProStarReader.h"
69  "/home/paraview/VTK/IO/Geometry/vtkPTSReader.h"
70  "/home/paraview/VTK/IO/Geometry/vtkSTLReader.h"
71  "/home/paraview/VTK/IO/Geometry/vtkSTLWriter.h"
72  "/home/paraview/VTK/IO/Geometry/vtkTecplotReader.h"
73  "/home/paraview/VTK/IO/Geometry/vtkWindBladeReader.h"
74  "/home/paraview/VTK/IO/Geometry/vtkXYZMolReader.h"
75  "/home/paraview/build/VTK/IO/Geometry/vtkIOGeometryModule.h"
76  )
77 endif()
78
79 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
80  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkIOGeometry-hierarchy.txt" FILES "/home/paraview/build/lib64/vtk/hierarchy/ParaView/vtkIOGeometry-hierarchy.txt")
81 endif()
82
83 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
84  foreach(file
85  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.9.so.5.9"
86  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.9.so.1"
87  )
88  if(EXISTS "${file}" AND
89  NOT IS_SYMLINK "${file}")
90  file(RPATH_CHECK
91  FILE "${file}"
92  RPATH "\$ORIGIN")
93  endif()
94  endforeach()
95  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
96  "/home/paraview/build/lib64/libvtkIOGeometry-pv5.9.so.5.9"
97  "/home/paraview/build/lib64/libvtkIOGeometry-pv5.9.so.1"
98  )
99  foreach(file
100  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.9.so.5.9"
101  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.9.so.1"
102  )
103  if(EXISTS "${file}" AND
104  NOT IS_SYMLINK "${file}")
105  file(RPATH_CHANGE
106  FILE "${file}"
107  OLD_RPATH "/home/paraview/build/lib64:"
108  NEW_RPATH "\$ORIGIN")
109  if(CMAKE_INSTALL_DO_STRIP)
110  execute_process(COMMAND "/usr/bin/strip" "${file}")
111  endif()
112  endif()
113  endforeach()
114 endif()
115
116 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
117  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.9.so" AND
118  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.9.so")
119  file(RPATH_CHECK
120  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.9.so"
121  RPATH "\$ORIGIN")
122  endif()
123  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkIOGeometry-pv5.9.so")
124  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.9.so" AND
125  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.9.so")
126  file(RPATH_CHANGE
127  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.9.so"
128  OLD_RPATH "/home/paraview/build/lib64:"
129  NEW_RPATH "\$ORIGIN")
130  if(CMAKE_INSTALL_DO_STRIP)
131  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv5.9.so")
132  endif()
133  endif()
134 endif()
135
