1 # Install script for directory: /home/paraview/VTK/IO/Core
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47  "/home/paraview/VTK/IO/Core/vtkUpdateCellsV8toV9.h"
48  "/home/paraview/VTK/IO/Core/vtkAbstractParticleWriter.h"
49  "/home/paraview/VTK/IO/Core/vtkAbstractPolyDataReader.h"
50  "/home/paraview/VTK/IO/Core/vtkArrayDataReader.h"
51  "/home/paraview/VTK/IO/Core/vtkArrayDataWriter.h"
52  "/home/paraview/VTK/IO/Core/vtkArrayReader.h"
53  "/home/paraview/VTK/IO/Core/vtkArrayWriter.h"
54  "/home/paraview/VTK/IO/Core/vtkASCIITextCodec.h"
55  "/home/paraview/VTK/IO/Core/vtkBase64InputStream.h"
56  "/home/paraview/VTK/IO/Core/vtkBase64OutputStream.h"
57  "/home/paraview/VTK/IO/Core/vtkBase64Utilities.h"
58  "/home/paraview/VTK/IO/Core/vtkDataCompressor.h"
59  "/home/paraview/VTK/IO/Core/vtkDelimitedTextWriter.h"
60  "/home/paraview/VTK/IO/Core/vtkGlobFileNames.h"
61  "/home/paraview/VTK/IO/Core/vtkInputStream.h"
62  "/home/paraview/VTK/IO/Core/vtkJavaScriptDataWriter.h"
63  "/home/paraview/VTK/IO/Core/vtkLZ4DataCompressor.h"
64  "/home/paraview/VTK/IO/Core/vtkLZMADataCompressor.h"
65  "/home/paraview/VTK/IO/Core/vtkNumberToString.h"
66  "/home/paraview/VTK/IO/Core/vtkOutputStream.h"
67  "/home/paraview/VTK/IO/Core/vtkSortFileNames.h"
68  "/home/paraview/VTK/IO/Core/vtkTextCodec.h"
69  "/home/paraview/VTK/IO/Core/vtkTextCodecFactory.h"
70  "/home/paraview/VTK/IO/Core/vtkUTF16TextCodec.h"
71  "/home/paraview/VTK/IO/Core/vtkUTF8TextCodec.h"
72  "/home/paraview/VTK/IO/Core/vtkWriter.h"
73  "/home/paraview/VTK/IO/Core/vtkZLibDataCompressor.h"
74  "/home/paraview/build/VTK/IO/Core/vtkIOCoreModule.h"
75  )
76 endif()
77
78 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
79  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkIOCore-hierarchy.txt" FILES "/home/paraview/build/lib64/vtk/hierarchy/ParaView/vtkIOCore-hierarchy.txt")
80 endif()
81
82 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
83  foreach(file
84  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.9.so.5.9"
85  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.9.so.1"
86  )
87  if(EXISTS "${file}" AND
88  NOT IS_SYMLINK "${file}")
89  file(RPATH_CHECK
90  FILE "${file}"
91  RPATH "\$ORIGIN")
92  endif()
93  endforeach()
94  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
95  "/home/paraview/build/lib64/libvtkIOCore-pv5.9.so.5.9"
96  "/home/paraview/build/lib64/libvtkIOCore-pv5.9.so.1"
97  )
98  foreach(file
99  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.9.so.5.9"
100  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.9.so.1"
101  )
102  if(EXISTS "${file}" AND
103  NOT IS_SYMLINK "${file}")
104  file(RPATH_CHANGE
105  FILE "${file}"
106  OLD_RPATH "/home/paraview/build/lib64:"
107  NEW_RPATH "\$ORIGIN")
108  if(CMAKE_INSTALL_DO_STRIP)
109  execute_process(COMMAND "/usr/bin/strip" "${file}")
110  endif()
111  endif()
112  endforeach()
113 endif()
114
115 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
116  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.9.so" AND
117  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.9.so")
118  file(RPATH_CHECK
119  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.9.so"
120  RPATH "\$ORIGIN")
121  endif()
122  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkIOCore-pv5.9.so")
123  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.9.so" AND
124  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.9.so")
125  file(RPATH_CHANGE
126  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.9.so"
127  OLD_RPATH "/home/paraview/build/lib64:"
128  NEW_RPATH "\$ORIGIN")
129  if(CMAKE_INSTALL_DO_STRIP)
130  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOCore-pv5.9.so")
131  endif()
132  endif()
133 endif()
134
