1 # Install script for directory: /home/paraview/VTK/Domains/Chemistry 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47 "/home/paraview/build/VTK/Domains/Chemistry/vtkChemistryConfigure.h" 48 "/home/paraview/VTK/Domains/Chemistry/vtkBlueObeliskData.h" 49 "/home/paraview/VTK/Domains/Chemistry/vtkBlueObeliskDataParser.h" 50 "/home/paraview/VTK/Domains/Chemistry/vtkCMLMoleculeReader.h" 51 "/home/paraview/VTK/Domains/Chemistry/vtkGaussianCubeReader2.h" 52 "/home/paraview/VTK/Domains/Chemistry/vtkMoleculeMapper.h" 53 "/home/paraview/VTK/Domains/Chemistry/vtkMoleculeToAtomBallFilter.h" 54 "/home/paraview/VTK/Domains/Chemistry/vtkMoleculeToBondStickFilter.h" 55 "/home/paraview/VTK/Domains/Chemistry/vtkMoleculeToLinesFilter.h" 56 "/home/paraview/VTK/Domains/Chemistry/vtkMoleculeToPolyDataFilter.h" 57 "/home/paraview/VTK/Domains/Chemistry/vtkPeriodicTable.h" 58 "/home/paraview/VTK/Domains/Chemistry/vtkPointSetToMoleculeFilter.h" 59 "/home/paraview/VTK/Domains/Chemistry/vtkProgrammableElectronicData.h" 60 "/home/paraview/VTK/Domains/Chemistry/vtkProteinRibbonFilter.h" 61 "/home/paraview/VTK/Domains/Chemistry/vtkSimpleBondPerceiver.h" 62 "/home/paraview/VTK/Domains/Chemistry/vtkVASPAnimationReader.h" 63 "/home/paraview/VTK/Domains/Chemistry/vtkVASPTessellationReader.h" 64 "/home/paraview/VTK/Domains/Chemistry/vtkXYZMolReader2.h" 65 "/home/paraview/build/VTK/Domains/Chemistry/vtkDomainsChemistryModule.h" 69 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 70 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkDomainsChemistry-hierarchy.txt
" FILES "/home/paraview/build/lib64/
vtk/hierarchy/ParaView/vtkDomainsChemistry-hierarchy.txt
") 73 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 75 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.9.so.5.9
" 76 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.9.so.1
" 78 if(EXISTS "${file}
" AND 79 NOT IS_SYMLINK "${file}
") 85 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 86 "/home/paraview/build/lib64/libvtkDomainsChemistry-pv5.9.so.5.9
" 87 "/home/paraview/build/lib64/libvtkDomainsChemistry-pv5.9.so.1
" 90 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.9.so.5.9
" 91 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.9.so.1
" 93 if(EXISTS "${file}
" AND 94 NOT IS_SYMLINK "${file}
") 97 OLD_RPATH "/home/paraview/build/lib64:
" 99 if(CMAKE_INSTALL_DO_STRIP) 100 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 106 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 107 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.9.so
" AND 108 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.9.so
") 110 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.9.so
" 113 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkDomainsChemistry-pv5.9.so
") 114 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.9.so
" AND 115 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.9.so
") 117 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.9.so
" 118 OLD_RPATH "/home/paraview/build/lib64:
" 119 NEW_RPATH "\$ORIGIN
") 120 if(CMAKE_INSTALL_DO_STRIP) 121 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkDomainsChemistry-pv5.9.so
