1 # Install script for directory: /home/paraview/VTK/Common/Transforms 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47 "/home/paraview/VTK/Common/Transforms/vtkAbstractTransform.h" 48 "/home/paraview/VTK/Common/Transforms/vtkCylindricalTransform.h" 49 "/home/paraview/VTK/Common/Transforms/vtkGeneralTransform.h" 50 "/home/paraview/VTK/Common/Transforms/vtkHomogeneousTransform.h" 51 "/home/paraview/VTK/Common/Transforms/vtkIdentityTransform.h" 52 "/home/paraview/VTK/Common/Transforms/vtkLandmarkTransform.h" 53 "/home/paraview/VTK/Common/Transforms/vtkLinearTransform.h" 54 "/home/paraview/VTK/Common/Transforms/vtkMatrixToHomogeneousTransform.h" 55 "/home/paraview/VTK/Common/Transforms/vtkMatrixToLinearTransform.h" 56 "/home/paraview/VTK/Common/Transforms/vtkPerspectiveTransform.h" 57 "/home/paraview/VTK/Common/Transforms/vtkSphericalTransform.h" 58 "/home/paraview/VTK/Common/Transforms/vtkThinPlateSplineTransform.h" 59 "/home/paraview/VTK/Common/Transforms/vtkTransform.h" 60 "/home/paraview/VTK/Common/Transforms/vtkTransform2D.h" 61 "/home/paraview/VTK/Common/Transforms/vtkTransformCollection.h" 62 "/home/paraview/VTK/Common/Transforms/vtkWarpTransform.h" 63 "/home/paraview/build/VTK/Common/Transforms/vtkCommonTransformsModule.h" 67 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 68 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkCommonTransforms-hierarchy.txt
" FILES "/home/paraview/build/lib64/
vtk/hierarchy/ParaView/vtkCommonTransforms-hierarchy.txt
") 71 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 73 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonTransforms-pv5.9.so.5.9
" 74 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonTransforms-pv5.9.so.1
" 76 if(EXISTS "${file}
" AND 77 NOT IS_SYMLINK "${file}
") 83 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 84 "/home/paraview/build/lib64/libvtkCommonTransforms-pv5.9.so.5.9
" 85 "/home/paraview/build/lib64/libvtkCommonTransforms-pv5.9.so.1
" 88 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonTransforms-pv5.9.so.5.9
" 89 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonTransforms-pv5.9.so.1
" 91 if(EXISTS "${file}
" AND 92 NOT IS_SYMLINK "${file}
") 95 OLD_RPATH "/home/paraview/build/lib64:
" 97 if(CMAKE_INSTALL_DO_STRIP) 98 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 104 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 105 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonTransforms-pv5.9.so
" AND 106 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonTransforms-pv5.9.so
") 108 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonTransforms-pv5.9.so
" 111 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkCommonTransforms-pv5.9.so
") 112 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonTransforms-pv5.9.so
" AND 113 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonTransforms-pv5.9.so
") 115 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonTransforms-pv5.9.so
" 116 OLD_RPATH "/home/paraview/build/lib64:
" 117 NEW_RPATH "\$ORIGIN
") 118 if(CMAKE_INSTALL_DO_STRIP) 119 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonTransforms-pv5.9.so
