1 # Install script for directory: /home/paraview/VTK/Common/Misc
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47  "/home/paraview/VTK/Common/Misc/vtkContourValues.h"
48  "/home/paraview/VTK/Common/Misc/vtkErrorCode.h"
49  "/home/paraview/VTK/Common/Misc/vtkFunctionParser.h"
50  "/home/paraview/VTK/Common/Misc/vtkHeap.h"
51  "/home/paraview/VTK/Common/Misc/vtkPolygonBuilder.h"
52  "/home/paraview/VTK/Common/Misc/vtkResourceFileLocator.h"
53  "/home/paraview/build/VTK/Common/Misc/vtkCommonMiscModule.h"
54  )
55 endif()
56
57 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
58  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkCommonMisc-hierarchy.txt" FILES "/home/paraview/build/lib64/vtk/hierarchy/ParaView/vtkCommonMisc-hierarchy.txt")
59 endif()
60
61 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
62  foreach(file
63  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.9.so.5.9"
64  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.9.so.1"
65  )
66  if(EXISTS "${file}" AND
67  NOT IS_SYMLINK "${file}")
68  file(RPATH_CHECK
69  FILE "${file}"
70  RPATH "\$ORIGIN")
71  endif()
72  endforeach()
73  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
74  "/home/paraview/build/lib64/libvtkCommonMisc-pv5.9.so.5.9"
75  "/home/paraview/build/lib64/libvtkCommonMisc-pv5.9.so.1"
76  )
77  foreach(file
78  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.9.so.5.9"
79  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.9.so.1"
80  )
81  if(EXISTS "${file}" AND
82  NOT IS_SYMLINK "${file}")
83  file(RPATH_CHANGE
84  FILE "${file}"
85  OLD_RPATH "/home/paraview/build/lib64:"
86  NEW_RPATH "\$ORIGIN")
87  if(CMAKE_INSTALL_DO_STRIP)
88  execute_process(COMMAND "/usr/bin/strip" "${file}")
89  endif()
90  endif()
91  endforeach()
92 endif()
93
94 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
95  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.9.so" AND
96  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.9.so")
97  file(RPATH_CHECK
98  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.9.so"
99  RPATH "\$ORIGIN")
100  endif()
101  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkCommonMisc-pv5.9.so")
102  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.9.so" AND
103  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.9.so")
104  file(RPATH_CHANGE
105  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.9.so"
106  OLD_RPATH "/home/paraview/build/lib64:"
107  NEW_RPATH "\$ORIGIN")
108  if(CMAKE_INSTALL_DO_STRIP)
109  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.9.so")
110  endif()
111  endif()
112 endif()
113
