1 # Install script for directory: /home/paraview/VTK/Common/ComputationalGeometry 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47 "/home/paraview/VTK/Common/ComputationalGeometry/vtkBilinearQuadIntersection.h" 48 "/home/paraview/VTK/Common/ComputationalGeometry/vtkCardinalSpline.h" 49 "/home/paraview/VTK/Common/ComputationalGeometry/vtkKochanekSpline.h" 50 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricBohemianDome.h" 51 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricBour.h" 52 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricBoy.h" 53 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricCatalanMinimal.h" 54 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricConicSpiral.h" 55 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricCrossCap.h" 56 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricDini.h" 57 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricEllipsoid.h" 58 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricEnneper.h" 59 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricFigure8Klein.h" 60 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricFunction.h" 61 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricHenneberg.h" 62 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricKlein.h" 63 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricKuen.h" 64 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricMobius.h" 65 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricPluckerConoid.h" 66 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricPseudosphere.h" 67 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricRandomHills.h" 68 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricRoman.h" 69 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricSpline.h" 70 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricSuperEllipsoid.h" 71 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricSuperToroid.h" 72 "/home/paraview/VTK/Common/ComputationalGeometry/vtkParametricTorus.h" 73 "/home/paraview/build/VTK/Common/ComputationalGeometry/vtkCommonComputationalGeometryModule.h" 77 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 78 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkCommonComputationalGeometry-hierarchy.txt
" FILES "/home/paraview/build/lib64/
vtk/hierarchy/ParaView/vtkCommonComputationalGeometry-hierarchy.txt
") 81 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 83 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonComputationalGeometry-pv5.9.so.5.9
" 84 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonComputationalGeometry-pv5.9.so.1
" 86 if(EXISTS "${file}
" AND 87 NOT IS_SYMLINK "${file}
") 93 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 94 "/home/paraview/build/lib64/libvtkCommonComputationalGeometry-pv5.9.so.5.9
" 95 "/home/paraview/build/lib64/libvtkCommonComputationalGeometry-pv5.9.so.1
" 98 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonComputationalGeometry-pv5.9.so.5.9
" 99 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonComputationalGeometry-pv5.9.so.1
" 101 if(EXISTS "${file}
" AND 102 NOT IS_SYMLINK "${file}
") 105 OLD_RPATH "/home/paraview/build/lib64:
" 106 NEW_RPATH "\$ORIGIN
") 107 if(CMAKE_INSTALL_DO_STRIP) 108 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 114 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 115 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonComputationalGeometry-pv5.9.so
" AND 116 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonComputationalGeometry-pv5.9.so
") 118 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonComputationalGeometry-pv5.9.so
" 121 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkCommonComputationalGeometry-pv5.9.so
") 122 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonComputationalGeometry-pv5.9.so
" AND 123 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonComputationalGeometry-pv5.9.so
") 125 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonComputationalGeometry-pv5.9.so
" 126 OLD_RPATH "/home/paraview/build/lib64:
" 127 NEW_RPATH "\$ORIGIN
") 128 if(CMAKE_INSTALL_DO_STRIP) 129 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonComputationalGeometry-pv5.9.so
