1 # Install script for directory: /home/paraview/VTKExtensions/Points 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47 "/home/paraview/VTKExtensions/Points/vtkBoundedPlaneSource.h" 48 "/home/paraview/VTKExtensions/Points/vtkBoundedVolumeSource.h" 49 "/home/paraview/build/VTKExtensions/Points/vtkPVVTKExtensionsPointsModule.h" 53 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 54 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkPVVTKExtensionsPoints-hierarchy.txt
" FILES "/home/paraview/build/lib64/
vtk/hierarchy/ParaView/vtkPVVTKExtensionsPoints-hierarchy.txt
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 59 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsPoints-pv5.9.so.5.9
" 60 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsPoints-pv5.9.so.1
" 62 if(EXISTS "${file}
" AND 63 NOT IS_SYMLINK "${file}
") 69 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 70 "/home/paraview/build/lib64/libvtkPVVTKExtensionsPoints-pv5.9.so.5.9
" 71 "/home/paraview/build/lib64/libvtkPVVTKExtensionsPoints-pv5.9.so.1
" 74 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsPoints-pv5.9.so.5.9
" 75 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsPoints-pv5.9.so.1
" 77 if(EXISTS "${file}
" AND 78 NOT IS_SYMLINK "${file}
") 81 OLD_RPATH "/home/paraview/build/lib64:
" 83 if(CMAKE_INSTALL_DO_STRIP) 84 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 90 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 91 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsPoints-pv5.9.so
" AND 92 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsPoints-pv5.9.so
") 94 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsPoints-pv5.9.so
" 97 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkPVVTKExtensionsPoints-pv5.9.so
") 98 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsPoints-pv5.9.so
" AND 99 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsPoints-pv5.9.so
") 101 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsPoints-pv5.9.so
" 102 OLD_RPATH "/home/paraview/build/lib64:
" 103 NEW_RPATH "\$ORIGIN
") 104 if(CMAKE_INSTALL_DO_STRIP) 105 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsPoints-pv5.9.so
