1 # Install script for directory: /home/paraview/VTKExtensions/Misc
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47  "/home/paraview/VTKExtensions/Misc/vtkPVChangeOfBasisHelper.h"
48  "/home/paraview/VTKExtensions/Misc/vtkAppendRectilinearGrid.h"
49  "/home/paraview/VTKExtensions/Misc/vtkAttributeDataReductionFilter.h"
50  "/home/paraview/VTKExtensions/Misc/vtkAttributeDataToTableFilter.h"
51  "/home/paraview/VTKExtensions/Misc/vtkCleanArrays.h"
52  "/home/paraview/VTKExtensions/Misc/vtkCompleteArrays.h"
53  "/home/paraview/VTKExtensions/Misc/vtkEnvironmentAnnotationFilter.h"
54  "/home/paraview/VTKExtensions/Misc/vtkExtractHistogram.h"
55  "/home/paraview/VTKExtensions/Misc/vtkMergeBlocks.h"
56  "/home/paraview/VTKExtensions/Misc/vtkMinMax.h"
57  "/home/paraview/VTKExtensions/Misc/vtkPExtractHistogram.h"
58  "/home/paraview/VTKExtensions/Misc/vtkPVBox.h"
59  "/home/paraview/VTKExtensions/Misc/vtkPVCylinder.h"
60  "/home/paraview/VTKExtensions/Misc/vtkPVMergeTables.h"
61  "/home/paraview/VTKExtensions/Misc/vtkPVMergeTablesMultiBlock.h"
62  "/home/paraview/VTKExtensions/Misc/vtkPVPlane.h"
63  "/home/paraview/VTKExtensions/Misc/vtkPVTransform.h"
64  "/home/paraview/VTKExtensions/Misc/vtkReductionFilter.h"
65  "/home/paraview/VTKExtensions/Misc/vtkSelectionSerializer.h"
66  "/home/paraview/VTKExtensions/Misc/vtkCompositeDataToUnstructuredGridFilter.h"
67  "/home/paraview/VTKExtensions/Misc/vtkDataObjectTreeToPointSetFilter.h"
68  "/home/paraview/build/VTKExtensions/Misc/vtkPVVTKExtensionsMiscModule.h"
69  )
70 endif()
71
72 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
73  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkPVVTKExtensionsMisc-hierarchy.txt" FILES "/home/paraview/build/lib64/vtk/hierarchy/ParaView/vtkPVVTKExtensionsMisc-hierarchy.txt")
74 endif()
75
76 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
77  foreach(file
78  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.9.so.5.9"
79  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.9.so.1"
80  )
81  if(EXISTS "${file}" AND
82  NOT IS_SYMLINK "${file}")
83  file(RPATH_CHECK
84  FILE "${file}"
85  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
86  endif()
87  endforeach()
88  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
89  "/home/paraview/build/lib64/libvtkPVVTKExtensionsMisc-pv5.9.so.5.9"
90  "/home/paraview/build/lib64/libvtkPVVTKExtensionsMisc-pv5.9.so.1"
91  )
92  foreach(file
93  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.9.so.5.9"
94  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.9.so.1"
95  )
96  if(EXISTS "${file}" AND
97  NOT IS_SYMLINK "${file}")
98  file(RPATH_CHANGE
99  FILE "${file}"
100  OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:"
101  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
102  if(CMAKE_INSTALL_DO_STRIP)
103  execute_process(COMMAND "/usr/bin/strip" "${file}")
104  endif()
105  endif()
106  endforeach()
107 endif()
108
109 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
110  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.9.so" AND
111  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.9.so")
112  file(RPATH_CHECK
113  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.9.so"
114  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
115  endif()
116  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkPVVTKExtensionsMisc-pv5.9.so")
117  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.9.so" AND
118  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.9.so")
119  file(RPATH_CHANGE
120  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.9.so"
121  OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:"
122  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
123  if(CMAKE_INSTALL_DO_STRIP)
124  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.9.so")
125  endif()
126  endif()
127 endif()
128
