1 # Install script for directory: /home/paraview/VTKExtensions/Core 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47 "/home/paraview/VTKExtensions/Core/vtkMemberFunctionCommand.h" 48 "/home/paraview/VTKExtensions/Core/vtkCommandOptions.h" 49 "/home/paraview/VTKExtensions/Core/vtkCommandOptionsXMLParser.h" 50 "/home/paraview/VTKExtensions/Core/vtkCommunicationErrorCatcher.h" 51 "/home/paraview/VTKExtensions/Core/vtkDistributedTrivialProducer.h" 52 "/home/paraview/VTKExtensions/Core/vtkFileSequenceParser.h" 53 "/home/paraview/VTKExtensions/Core/vtkLogRecorder.h" 54 "/home/paraview/VTKExtensions/Core/vtkMultiProcessControllerHelper.h" 55 "/home/paraview/VTKExtensions/Core/vtkPVCompositeDataPipeline.h" 56 "/home/paraview/VTKExtensions/Core/vtkPVInformationKeys.h" 57 "/home/paraview/VTKExtensions/Core/vtkPVLogger.h" 58 "/home/paraview/VTKExtensions/Core/vtkPVNullSource.h" 59 "/home/paraview/VTKExtensions/Core/vtkPVPostFilter.h" 60 "/home/paraview/VTKExtensions/Core/vtkPVPostFilterExecutive.h" 61 "/home/paraview/VTKExtensions/Core/vtkPVTestUtilities.h" 62 "/home/paraview/VTKExtensions/Core/vtkPVTrivialProducer.h" 63 "/home/paraview/VTKExtensions/Core/vtkPVXMLElement.h" 64 "/home/paraview/VTKExtensions/Core/vtkPVXMLParser.h" 65 "/home/paraview/VTKExtensions/Core/vtkStringList.h" 66 "/home/paraview/VTKExtensions/Core/vtkSubsetInclusionLattice.h" 67 "/home/paraview/VTKExtensions/Core/vtkUndoElement.h" 68 "/home/paraview/VTKExtensions/Core/vtkUndoSet.h" 69 "/home/paraview/VTKExtensions/Core/vtkUndoStack.h" 70 "/home/paraview/build/VTKExtensions/Core/vtkPVVTKExtensionsCoreModule.h" 74 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 75 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkPVVTKExtensionsCore-hierarchy.txt
" FILES "/home/paraview/build/lib64/
vtk/hierarchy/ParaView/vtkPVVTKExtensionsCore-hierarchy.txt
") 78 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 80 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.9.so.5.9
" 81 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.9.so.1
" 83 if(EXISTS "${file}
" AND 84 NOT IS_SYMLINK "${file}
") 90 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 91 "/home/paraview/build/lib64/libvtkPVVTKExtensionsCore-pv5.9.so.5.9
" 92 "/home/paraview/build/lib64/libvtkPVVTKExtensionsCore-pv5.9.so.1
" 95 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.9.so.5.9
" 96 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.9.so.1
" 98 if(EXISTS "${file}
" AND 99 NOT IS_SYMLINK "${file}
") 102 OLD_RPATH "/home/paraview/build/lib64:
" 103 NEW_RPATH "\$ORIGIN
") 104 if(CMAKE_INSTALL_DO_STRIP) 105 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 111 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 112 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.9.so
" AND 113 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.9.so
") 115 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.9.so
" 118 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkPVVTKExtensionsCore-pv5.9.so
") 119 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.9.so
" AND 120 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.9.so
") 122 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.9.so
" 123 OLD_RPATH "/home/paraview/build/lib64:
" 124 NEW_RPATH "\$ORIGIN
") 125 if(CMAKE_INSTALL_DO_STRIP) 126 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.9.so
