1 # Install script for directory: /home/paraview/VTKExtensions/AMR 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47 "/home/paraview/VTKExtensions/AMR/vtkAMRConnectivity.h" 48 "/home/paraview/VTKExtensions/AMR/vtkAMRDualClip.h" 49 "/home/paraview/VTKExtensions/AMR/vtkAMRDualContour.h" 50 "/home/paraview/VTKExtensions/AMR/vtkAMRDualGridHelper.h" 51 "/home/paraview/VTKExtensions/AMR/vtkAMRFragmentIntegration.h" 52 "/home/paraview/VTKExtensions/AMR/vtkAMRFragmentsFilter.h" 53 "/home/paraview/VTKExtensions/AMR/vtkPVAMRDualClip.h" 54 "/home/paraview/VTKExtensions/AMR/vtkPVAMRDualContour.h" 55 "/home/paraview/VTKExtensions/AMR/vtkPVAMRFragmentIntegration.h" 56 "/home/paraview/build/VTKExtensions/AMR/vtkPVVTKExtensionsAMRModule.h" 60 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 61 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkPVVTKExtensionsAMR-hierarchy.txt
" FILES "/home/paraview/build/lib64/
vtk/hierarchy/ParaView/vtkPVVTKExtensionsAMR-hierarchy.txt
") 64 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsAMR-pv5.9.so.5.9
" 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsAMR-pv5.9.so.1
" 69 if(EXISTS "${file}
") 73 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 76 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 77 "/home/paraview/build/lib64/libvtkPVVTKExtensionsAMR-pv5.9.so.5.9
" 78 "/home/paraview/build/lib64/libvtkPVVTKExtensionsAMR-pv5.9.so.1
" 81 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsAMR-pv5.9.so.5.9
" 82 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsAMR-pv5.9.so.1
" 84 if(EXISTS "${file}
" AND 85 NOT IS_SYMLINK "${file}
") 88 OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:
" 89 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 90 if(CMAKE_INSTALL_DO_STRIP) 91 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 97 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 98 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsAMR-pv5.9.so
" AND 99 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsAMR-pv5.9.so
") 101 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsAMR-pv5.9.so
" 102 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 104 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkPVVTKExtensionsAMR-pv5.9.so
") 105 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsAMR-pv5.9.so
" AND 106 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsAMR-pv5.9.so
") 108 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsAMR-pv5.9.so
" 109 OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:
" 110 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 111 if(CMAKE_INSTALL_DO_STRIP) 112 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsAMR-pv5.9.so
