1 # Install script for directory: /home/paraview/ThirdParty/cinemasci
45 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/cdb" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/cdb/__init__.py")
47 endif()
48
49 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
50  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/cis" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/cis/channel.py")
51 endif()
52
53 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
54  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/cis" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/cis/colormap.py")
55 endif()
56
57 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
58  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/cis" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/cis/image.py")
59 endif()
60
61 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
62  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/cis" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/cis/__init__.py")
63 endif()
64
65 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
66  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/cis" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/cis/layer.py")
67 endif()
68
69 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
70  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/cis/read" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/cis/read/file.py")
71 endif()
72
73 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
74  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/cis/read" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/cis/read/hdf5.py")
75 endif()
76
77 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
78  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/cis/read" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/cis/read/__init__.py")
79 endif()
80
81 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
82  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/cis" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/cis/render.py")
83 endif()
84
85 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
86  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/cis/write" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/cis/write/file.py")
87 endif()
88
89 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/cis/write" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/cis/write/hdf5.py")
91 endif()
92
93 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
94  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/cis/write" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/cis/write/__init__.py")
95 endif()
96
97 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
98  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/__init__.py")
99 endif()
100
101 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
102  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/pynb" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/pynb/__init__.py")
103 endif()
104
105 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
106  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/server" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/server/cinema_test.html")
107 endif()
108
109 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
110  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/server" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/server/error_no-database.html")
111 endif()
112
113 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
114  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/server" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/server/__init__.py")
115 endif()
116
117 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
118  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/server" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/server/__main__.py")
119 endif()
120
121 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
122  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/version.py")
123 endif()
124
125 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
126  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers/cinema/explorer/2.0/css" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/explorer/2.0/css/viewer.css")
127 endif()
128
129 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
130  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers/cinema/explorer/2.0" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/explorer/2.0/databases.json")
131 endif()
132
133 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
134  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers/cinema/explorer/2.0/js" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/explorer/2.0/js/main.js")
135 endif()
136
137 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
138  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema_explorer.html")
139 endif()
140
141 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
142  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers/cinema/lib" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/lib/d3.v4.min.js")
143 endif()
144
145 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
146  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers/cinema/lib" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/lib/databases.js")
147 endif()
148
149 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
150  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers/cinema/view/2.0" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/view/2.0/copyright.md")
151 endif()
152
153 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
154  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers/cinema/view/2.0/css" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/view/2.0/css/common.css")
155 endif()
156
157 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
158  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers/cinema/view/2.0/css" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/view/2.0/css/range-css.css")
159 endif()
160
161 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
162  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers/cinema/view/2.0/css" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/view/2.0/css/range-css.textClipping")
163 endif()
164
165 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
166  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers/cinema/view/2.0/css" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/view/2.0/css/select-css.css")
167 endif()
168
169 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
170  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers/cinema/view/2.0/css" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/view/2.0/css/view.css")
171 endif()
172
173 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
174  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers/cinema/view/2.0" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/view/2.0/databases.json")
175 endif()
176
177 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
178  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers/cinema/view/2.0/images" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/view/2.0/images/empty.png")
179 endif()
180
181 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
182  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers/cinema/view/2.0" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/view/2.0/license.md")
183 endif()
184
185 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
186  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers/cinema/view/2.0" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/view/2.0/version.md")
187 endif()
188
189 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
190  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema_view.html")
191 endif()
192
193 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
194  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/citation.md")
195 endif()
196
197 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
198  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/__init__.py")
199 endif()
200
201 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
202  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/license.md")
203 endif()
204
205 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
206  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/readme.md")
207 endif()
208
209 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
210  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/test_explorer.html")
211 endif()
212
213 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
214  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/test_view.html")
215 endif()
216
217 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
218  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.9/site-packages/paraview/tpl/cinemasci/viewers" TYPE FILE FILES "/home/paraview/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/version.md")
219 endif()
220
version
copyright
range
