1 # Install script for directory: /home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/libb64 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
"xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/lib64" TYPE STATIC_LIBRARY FILES
"/home/paraview/build/lib64/libb64_catalyst2.0.a")
