1 # Install script for directory: /home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
"xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9/catalyst" TYPE FILE FILES
47 "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/conduit_endianness_types.h" 48 "/home/paraview/build/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/conduit_exports.h" 49 "/home/paraview/build/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/conduit_config.h" 50 "/home/paraview/build/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/conduit_bitwidth_style_types.h" 51 "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/conduit.hpp" 52 "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/conduit_core.hpp" 53 "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/conduit_endianness.hpp" 54 "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/conduit_data_array.hpp" 55 "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/conduit_data_type.hpp" 56 "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/conduit_node.hpp" 57 "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/conduit_generator.hpp" 58 "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/conduit_error.hpp" 59 "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/conduit_node_iterator.hpp" 60 "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/conduit_schema.hpp" 61 "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/conduit_log.hpp" 62 "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/conduit_utils.hpp" 63 "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/c/conduit.h" 64 "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/c/conduit_datatype.h" 65 "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/c/conduit_node.h" 66 "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/c/conduit_cpp_to_c.hpp" 67 "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/c/conduit_utils.h" 68 "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/conduit/c/catalyst_conduit_mangle.h" 72 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xUnspecifiedx
" OR NOT CMAKE_INSTALL_COMPONENT) 73 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE STATIC_LIBRARY FILES "/home/paraview/build/lib64/libconduit_catalyst2.0.a
