1 # Install script for directory: /home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/blueprint
45 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE STATIC_LIBRARY FILES "/home/paraview/build/lib64/libblueprint_catalyst2.0.a")
47 endif()
48
49 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
50  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9/catalyst" TYPE FILE FILES
51  "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/blueprint/conduit_blueprint.hpp"
52  "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/blueprint/conduit_blueprint_mesh.hpp"
53  "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/blueprint/conduit_blueprint_mesh_examples.hpp"
54  "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/blueprint/conduit_blueprint_mcarray.hpp"
55  "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/blueprint/conduit_blueprint_mcarray_examples.hpp"
56  "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/blueprint/conduit_blueprint_zfparray.hpp"
57  "/home/paraview/build/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/blueprint/conduit_blueprint_exports.h"
58  "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/blueprint/c/conduit_blueprint.h"
59  "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/blueprint/c/conduit_blueprint_mcarray.h"
60  "/home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/blueprint/c/conduit_blueprint_mesh.h"
61  )
62 endif()
63
