1 # Install script for directory: /home/paraview/ThirdParty/catalyst/vtkcatalyst/catalyst
47  include("/home/paraview/build/ThirdParty/catalyst/vtkcatalyst/catalyst/core/cmake_install.cmake")
48 endif()
49
50 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
51  # Include the install script for the subdirectory.
52  include("/home/paraview/build/ThirdParty/catalyst/vtkcatalyst/catalyst/thirdparty/conduit/cmake_install.cmake")
53 endif()
54
55 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
56  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.9/catalyst/catalyst-targets.cmake")
57  file(DIFFERENT EXPORT_FILE_CHANGED FILES
58  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.9/catalyst/catalyst-targets.cmake"
59  "/home/paraview/build/ThirdParty/catalyst/vtkcatalyst/catalyst/CMakeFiles/Export/lib64/cmake/paraview-5.9/catalyst/catalyst-targets.cmake")
60  if(EXPORT_FILE_CHANGED)
61  file(GLOB OLD_CONFIG_FILES "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.9/catalyst/catalyst-targets-*.cmake")
62  if(OLD_CONFIG_FILES)
63  message(STATUS "Old export file \"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.9/catalyst/catalyst-targets.cmake\" will be replaced. Removing files [${OLD_CONFIG_FILES}].")
64  file(REMOVE ${OLD_CONFIG_FILES})
65  endif()
66  endif()
67  endif()
68  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.9/catalyst" TYPE FILE FILES "/home/paraview/build/ThirdParty/catalyst/vtkcatalyst/catalyst/CMakeFiles/Export/lib64/cmake/paraview-5.9/catalyst/catalyst-targets.cmake")
69  if("${CMAKE_INSTALL_CONFIG_NAME}" MATCHES "^([Dd][Ee][Bb][Uu][Gg])$")
70  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.9/catalyst" TYPE FILE FILES "/home/paraview/build/ThirdParty/catalyst/vtkcatalyst/catalyst/CMakeFiles/Export/lib64/cmake/paraview-5.9/catalyst/catalyst-targets-debug.cmake")
71  endif()
72 endif()
73
74 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xUnspecifiedx" OR NOT CMAKE_INSTALL_COMPONENT)
75  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.9/catalyst" TYPE FILE FILES
76  "/home/paraview/build/lib64/cmake/paraview-5.9/catalyst/catalyst-version.cmake"
77  "/home/paraview/build/lib64/cmake/paraview-5.9/catalyst/catalyst-config.cmake"
78  "/home/paraview/build/lib64/cmake/paraview-5.9/catalyst/catalyst-macros.cmake"
79  )
80 endif()
81
version
