1 # Install script for directory: /home/paraview/Remoting/ServerManager
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47  "/home/paraview/Remoting/ServerManager/vtkSMMessageMinimal.h"
48  "/home/paraview/Remoting/ServerManager/vtkLoadStateOptions.h"
49  "/home/paraview/Remoting/ServerManager/vtkRemoteWriterHelper.h"
50  "/home/paraview/Remoting/ServerManager/vtkPVCatalystChannelInformation.h"
51  "/home/paraview/Remoting/ServerManager/vtkPVCatalystSessionCore.h"
52  "/home/paraview/Remoting/ServerManager/vtkPVFilePathEncodingHelper.h"
53  "/home/paraview/Remoting/ServerManager/vtkPVProxyDefinitionIterator.h"
54  "/home/paraview/Remoting/ServerManager/vtkPVSessionBase.h"
55  "/home/paraview/Remoting/ServerManager/vtkPVSessionCore.h"
56  "/home/paraview/Remoting/ServerManager/vtkPVSessionCoreInterpreterHelper.h"
57  "/home/paraview/Remoting/ServerManager/vtkPVSessionServer.h"
58  "/home/paraview/Remoting/ServerManager/vtkSIArraySelectionProperty.h"
59  "/home/paraview/Remoting/ServerManager/vtkSICollaborationManager.h"
60  "/home/paraview/Remoting/ServerManager/vtkSICompoundSourceProxy.h"
61  "/home/paraview/Remoting/ServerManager/vtkSIDataArrayProperty.h"
62  "/home/paraview/Remoting/ServerManager/vtkSIDataArraySelectionProperty.h"
63  "/home/paraview/Remoting/ServerManager/vtkSIDirectoryProxy.h"
64  "/home/paraview/Remoting/ServerManager/vtkSIDoubleMapProperty.h"
65  "/home/paraview/Remoting/ServerManager/vtkSIDoubleVectorProperty.h"
66  "/home/paraview/Remoting/ServerManager/vtkSIIdTypeVectorProperty.h"
67  "/home/paraview/Remoting/ServerManager/vtkSIIndexSelectionProperty.h"
68  "/home/paraview/Remoting/ServerManager/vtkSIInputProperty.h"
69  "/home/paraview/Remoting/ServerManager/vtkSIIntVectorProperty.h"
70  "/home/paraview/Remoting/ServerManager/vtkSIMetaReaderProxy.h"
71  "/home/paraview/Remoting/ServerManager/vtkSIMultiplexerSourceProxy.h"
72  "/home/paraview/Remoting/ServerManager/vtkSIObject.h"
73  "/home/paraview/Remoting/ServerManager/vtkSIProperty.h"
74  "/home/paraview/Remoting/ServerManager/vtkSIProxy.h"
75  "/home/paraview/Remoting/ServerManager/vtkSIProxyDefinitionManager.h"
76  "/home/paraview/Remoting/ServerManager/vtkSIProxyProperty.h"
77  "/home/paraview/Remoting/ServerManager/vtkSISILProperty.h"
78  "/home/paraview/Remoting/ServerManager/vtkSISourceProxy.h"
79  "/home/paraview/Remoting/ServerManager/vtkSIStringVectorProperty.h"
80  "/home/paraview/Remoting/ServerManager/vtkSITimeLabelProperty.h"
81  "/home/paraview/Remoting/ServerManager/vtkSITimeRangeProperty.h"
82  "/home/paraview/Remoting/ServerManager/vtkSITimeStepsProperty.h"
83  "/home/paraview/Remoting/ServerManager/vtkSIVectorProperty.h"
84  "/home/paraview/Remoting/ServerManager/vtkSIWriterProxy.h"
85  "/home/paraview/Remoting/ServerManager/vtkSMAMRLevelsDomain.h"
86  "/home/paraview/Remoting/ServerManager/vtkSMArrayListDomain.h"
87  "/home/paraview/Remoting/ServerManager/vtkSMArrayRangeDomain.h"
88  "/home/paraview/Remoting/ServerManager/vtkSMArraySelectionDomain.h"
89  "/home/paraview/Remoting/ServerManager/vtkSMBooleanDomain.h"
90  "/home/paraview/Remoting/ServerManager/vtkSMBoundsDomain.h"
91  "/home/paraview/Remoting/ServerManager/vtkSMCollaborationManager.h"
92  "/home/paraview/Remoting/ServerManager/vtkSMCompositeTreeDomain.h"
93  "/home/paraview/Remoting/ServerManager/vtkSMCompoundProxyDefinitionLoader.h"
94  "/home/paraview/Remoting/ServerManager/vtkSMCompoundSourceProxy.h"
95  "/home/paraview/Remoting/ServerManager/vtkSMCompoundSourceProxyDefinitionBuilder.h"
96  "/home/paraview/Remoting/ServerManager/vtkSMCoreUtilities.h"
97  "/home/paraview/Remoting/ServerManager/vtkSMDataAssemblyDomain.h"
98  "/home/paraview/Remoting/ServerManager/vtkSMDataExtractWriterProxy.h"
99  "/home/paraview/Remoting/ServerManager/vtkSMDataSourceProxy.h"
100  "/home/paraview/Remoting/ServerManager/vtkSMDataTypeDomain.h"
101  "/home/paraview/Remoting/ServerManager/vtkSMDeserializer.h"
102  "/home/paraview/Remoting/ServerManager/vtkSMDeserializerProtobuf.h"
103  "/home/paraview/Remoting/ServerManager/vtkSMDeserializerXML.h"
104  "/home/paraview/Remoting/ServerManager/vtkSMDeserializerXMLCache.h"
105  "/home/paraview/Remoting/ServerManager/vtkSMDimensionsDomain.h"
106  "/home/paraview/Remoting/ServerManager/vtkSMDirectoryProxy.h"
107  "/home/paraview/Remoting/ServerManager/vtkSMDiscreteDoubleDomain.h"
108  "/home/paraview/Remoting/ServerManager/vtkSMDocumentation.h"
109  "/home/paraview/Remoting/ServerManager/vtkSMDomain.h"
110  "/home/paraview/Remoting/ServerManager/vtkSMDomainIterator.h"
111  "/home/paraview/Remoting/ServerManager/vtkSMDoubleMapProperty.h"
112  "/home/paraview/Remoting/ServerManager/vtkSMDoubleMapPropertyIterator.h"
113  "/home/paraview/Remoting/ServerManager/vtkSMDoubleRangeDomain.h"
114  "/home/paraview/Remoting/ServerManager/vtkSMDoubleVectorProperty.h"
115  "/home/paraview/Remoting/ServerManager/vtkSMEnumerationDomain.h"
116  "/home/paraview/Remoting/ServerManager/vtkSMExtentDomain.h"
117  "/home/paraview/Remoting/ServerManager/vtkSMExtractsController.h"
118  "/home/paraview/Remoting/ServerManager/vtkSMExtractTriggerProxy.h"
119  "/home/paraview/Remoting/ServerManager/vtkSMExtractWriterProxy.h"
120  "/home/paraview/Remoting/ServerManager/vtkSMFieldDataDomain.h"
121  "/home/paraview/Remoting/ServerManager/vtkSMFileListDomain.h"
122  "/home/paraview/Remoting/ServerManager/vtkSMFileUtilities.h"
123  "/home/paraview/Remoting/ServerManager/vtkSMFixedTypeDomain.h"
124  "/home/paraview/Remoting/ServerManager/vtkSMIdTypeVectorProperty.h"
125  "/home/paraview/Remoting/ServerManager/vtkSMIndexSelectionDomain.h"
126  "/home/paraview/Remoting/ServerManager/vtkSMInputArrayDomain.h"
127  "/home/paraview/Remoting/ServerManager/vtkSMInputFileNameDomain.h"
128  "/home/paraview/Remoting/ServerManager/vtkSMInputProperty.h"
129  "/home/paraview/Remoting/ServerManager/vtkSMIntRangeDomain.h"
130  "/home/paraview/Remoting/ServerManager/vtkSMIntVectorProperty.h"
131  "/home/paraview/Remoting/ServerManager/vtkSMLink.h"
132  "/home/paraview/Remoting/ServerManager/vtkSMLoadStateOptionsProxy.h"
133  "/home/paraview/Remoting/ServerManager/vtkSMMapProperty.h"
134  "/home/paraview/Remoting/ServerManager/vtkSMMessage.h"
135  "/home/paraview/Remoting/ServerManager/vtkSMMultiplexerSourceProxy.h"
136  "/home/paraview/Remoting/ServerManager/vtkSMMultiplexerInputDomain.h"
137  "/home/paraview/Remoting/ServerManager/vtkSMNamedPropertyIterator.h"
138  "/home/paraview/Remoting/ServerManager/vtkSMNullProxy.h"
139  "/home/paraview/Remoting/ServerManager/vtkSMNumberOfComponentsDomain.h"
140  "/home/paraview/Remoting/ServerManager/vtkSMObject.h"
141  "/home/paraview/Remoting/ServerManager/vtkSMOrderedPropertyIterator.h"
142  "/home/paraview/Remoting/ServerManager/vtkSMOutputPort.h"
143  "/home/paraview/Remoting/ServerManager/vtkSMParaViewPipelineController.h"
144  "/home/paraview/Remoting/ServerManager/vtkSMPipelineState.h"
145  "/home/paraview/Remoting/ServerManager/vtkSMPluginLoaderProxy.h"
146  "/home/paraview/Remoting/ServerManager/vtkSMPluginManager.h"
147  "/home/paraview/Remoting/ServerManager/vtkSMProperty.h"
148  "/home/paraview/Remoting/ServerManager/vtkSMPropertyGroup.h"
149  "/home/paraview/Remoting/ServerManager/vtkSMPropertyHelper.h"
150  "/home/paraview/Remoting/ServerManager/vtkSMPropertyIterator.h"
151  "/home/paraview/Remoting/ServerManager/vtkSMPropertyLink.h"
152  "/home/paraview/Remoting/ServerManager/vtkSMPropertyModificationUndoElement.h"
153  "/home/paraview/Remoting/ServerManager/vtkSMProxy.h"
154  "/home/paraview/Remoting/ServerManager/vtkSMProxyDefinitionManager.h"
155  "/home/paraview/Remoting/ServerManager/vtkSMProxyGroupDomain.h"
156  "/home/paraview/Remoting/ServerManager/vtkSMProxyInitializationHelper.h"
157  "/home/paraview/Remoting/ServerManager/vtkSMProxyIterator.h"
158  "/home/paraview/Remoting/ServerManager/vtkSMProxyLink.h"
159  "/home/paraview/Remoting/ServerManager/vtkSMProxyListDomain.h"
160  "/home/paraview/Remoting/ServerManager/vtkSMProxyLocator.h"
161  "/home/paraview/Remoting/ServerManager/vtkSMProxyManager.h"
162  "/home/paraview/Remoting/ServerManager/vtkSMProxyManagerUtilities.h"
163  "/home/paraview/Remoting/ServerManager/vtkSMProxyProperty.h"
164  "/home/paraview/Remoting/ServerManager/vtkSMProxySelectionModel.h"
165  "/home/paraview/Remoting/ServerManager/vtkSMPSWriterProxy.h"
166  "/home/paraview/Remoting/ServerManager/vtkSMPWriterProxy.h"
167  "/home/paraview/Remoting/ServerManager/vtkSMReaderFactory.h"
168  "/home/paraview/Remoting/ServerManager/vtkSMReaderReloadHelper.h"
169  "/home/paraview/Remoting/ServerManager/vtkSMRemoteObject.h"
170  "/home/paraview/Remoting/ServerManager/vtkSMRemoteObjectUpdateUndoElement.h"
171  "/home/paraview/Remoting/ServerManager/vtkSMSelfGeneratingSourceProxy.h"
172  "/home/paraview/Remoting/ServerManager/vtkSMServerStateLocator.h"
173  "/home/paraview/Remoting/ServerManager/vtkSMSession.h"
174  "/home/paraview/Remoting/ServerManager/vtkSMSessionClient.h"
175  "/home/paraview/Remoting/ServerManager/vtkSMSessionObject.h"
176  "/home/paraview/Remoting/ServerManager/vtkSMSessionProxyManager.h"
177  "/home/paraview/Remoting/ServerManager/vtkSMSettings.h"
178  "/home/paraview/Remoting/ServerManager/vtkSMSettingsProxy.h"
179  "/home/paraview/Remoting/ServerManager/vtkSMSILDomain.h"
180  "/home/paraview/Remoting/ServerManager/vtkSMSILModel.h"
181  "/home/paraview/Remoting/ServerManager/vtkSMSourceProxy.h"
182  "/home/paraview/Remoting/ServerManager/vtkSMStateLoader.h"
183  "/home/paraview/Remoting/ServerManager/vtkSMStateLocator.h"
184  "/home/paraview/Remoting/ServerManager/vtkSMStateVersionController.h"
185  "/home/paraview/Remoting/ServerManager/vtkSMStringListDomain.h"
186  "/home/paraview/Remoting/ServerManager/vtkSMStringVectorProperty.h"
187  "/home/paraview/Remoting/ServerManager/vtkSMSubsetInclusionLatticeDomain.h"
188  "/home/paraview/Remoting/ServerManager/vtkSMTimeKeeper.h"
189  "/home/paraview/Remoting/ServerManager/vtkSMTimeKeeperProxy.h"
190  "/home/paraview/Remoting/ServerManager/vtkSMTimeStepIndexDomain.h"
191  "/home/paraview/Remoting/ServerManager/vtkSMTrace.h"
192  "/home/paraview/Remoting/ServerManager/vtkSMUncheckedPropertyHelper.h"
193  "/home/paraview/Remoting/ServerManager/vtkSMUndoElement.h"
194  "/home/paraview/Remoting/ServerManager/vtkSMUndoStack.h"
195  "/home/paraview/Remoting/ServerManager/vtkSMUndoStackBuilder.h"
196  "/home/paraview/Remoting/ServerManager/vtkSMVectorProperty.h"
197  "/home/paraview/Remoting/ServerManager/vtkSMWriterFactory.h"
198  "/home/paraview/Remoting/ServerManager/vtkSMWriterProxy.h"
199  "/home/paraview/Remoting/ServerManager/vtkSIVectorPropertyTemplate.h"
200  "/home/paraview/Remoting/ServerManager/vtkSMRangeDomainTemplate.h"
201  "/home/paraview/build/Remoting/ServerManager/vtkRemotingServerManagerModule.h"
202  "/home/paraview/Remoting/ServerManager/vtkSIVectorPropertyTemplate.txx"
203  "/home/paraview/Remoting/ServerManager/vtkSMRangeDomainTemplate.txx"
204  )
205 endif()
206
207 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
208  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkRemotingServerManager-hierarchy.txt" FILES "/home/paraview/build/lib64/vtk/hierarchy/ParaView/vtkRemotingServerManager-hierarchy.txt")
209 endif()
210
211 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
212  foreach(file
213  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingServerManager-pv5.9.so.5.9"
214  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingServerManager-pv5.9.so.1"
215  )
216  if(EXISTS "${file}" AND
217  NOT IS_SYMLINK "${file}")
218  file(RPATH_CHECK
219  FILE "${file}"
220  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
221  endif()
222  endforeach()
223  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
224  "/home/paraview/build/lib64/libvtkRemotingServerManager-pv5.9.so.5.9"
225  "/home/paraview/build/lib64/libvtkRemotingServerManager-pv5.9.so.1"
226  )
227  foreach(file
228  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingServerManager-pv5.9.so.5.9"
229  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingServerManager-pv5.9.so.1"
230  )
231  if(EXISTS "${file}" AND
232  NOT IS_SYMLINK "${file}")
233  file(RPATH_CHANGE
234  FILE "${file}"
235  OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:"
236  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
237  if(CMAKE_INSTALL_DO_STRIP)
238  execute_process(COMMAND "/usr/bin/strip" "${file}")
239  endif()
240  endif()
241  endforeach()
242 endif()
243
244 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
245  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingServerManager-pv5.9.so" AND
246  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingServerManager-pv5.9.so")
247  file(RPATH_CHECK
248  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingServerManager-pv5.9.so"
249  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
250  endif()
251  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkRemotingServerManager-pv5.9.so")
252  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingServerManager-pv5.9.so" AND
253  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingServerManager-pv5.9.so")
254  file(RPATH_CHANGE
255  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingServerManager-pv5.9.so"
256  OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:"
257  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
258  if(CMAKE_INSTALL_DO_STRIP)
259  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingServerManager-pv5.9.so")
260  endif()
261  endif()
262 endif()
263
264 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
265  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES "/home/paraview/build/Remoting/ServerManager/vtkPVMessage.pb.h")
266 endif()
267
