1 # Install script for directory: /home/paraview/Remoting/ClientServerStream 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47 "/home/paraview/Remoting/ClientServerStream/vtkClientServerID.h" 48 "/home/paraview/Remoting/ClientServerStream/vtkClientServerInterpreter.h" 49 "/home/paraview/Remoting/ClientServerStream/vtkClientServerInterpreterInitializer.h" 50 "/home/paraview/Remoting/ClientServerStream/vtkClientServerStream.h" 51 "/home/paraview/Remoting/ClientServerStream/vtkClientServerStreamInstantiator.h" 52 "/home/paraview/build/Remoting/ClientServerStream/vtkRemotingClientServerStreamModule.h" 56 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 57 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkRemotingClientServerStream-hierarchy.txt
" FILES "/home/paraview/build/lib64/
vtk/hierarchy/ParaView/vtkRemotingClientServerStream-hierarchy.txt
") 60 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 62 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.9.so.5.9
" 63 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.9.so.1
" 65 if(EXISTS "${file}
") 72 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 73 "/home/paraview/build/lib64/libvtkRemotingClientServerStream-pv5.9.so.5.9
" 74 "/home/paraview/build/lib64/libvtkRemotingClientServerStream-pv5.9.so.1
" 77 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.9.so.5.9
" 78 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.9.so.1
" 80 if(EXISTS "${file}
" AND 81 NOT IS_SYMLINK "${file}
") 84 OLD_RPATH "/home/paraview/build/lib64:
" 86 if(CMAKE_INSTALL_DO_STRIP) 87 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 93 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 94 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.9.so
" AND 95 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.9.so
") 97 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.9.so
" 100 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkRemotingClientServerStream-pv5.9.so
") 101 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.9.so
" AND 102 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.9.so
") 104 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.9.so
" 105 OLD_RPATH "/home/paraview/build/lib64:
" 106 NEW_RPATH "\$ORIGIN
") 107 if(CMAKE_INSTALL_DO_STRIP) 108 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.9.so
