ParticleAdaptor.h
3  Program: ParaView
4  Module: ParticleAdaptor.h
5
6  Copyright (c) Sandia Corporation, Kitware, Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 =========================================================================*/
32 #ifndef ParticleAdaptor_h
33 #define ParticleAdaptor_h
35 #ifdef __cplusplus
36 extern "C" {
37 #endif
38
39 void coprocessorinitialize(void* handle);
40
41 // Description:
42 // creates an image based on particle positions passed in xyz.
43 // n is the number of particles
44 // xyz particle locations in interlaced format (x1,y1,z1,x2,y2,z2,...)
45 // bounds the bounds of the space (xmin,ymin,zmin,xmax,ymax,zmax)
46 // leave as null if there are no bounds
47 // r is the radius of the particles as rendered
48 // attr the attribute to color by, should be of length n
49 // min and max are the minimum and maximum value of the attributes
50 // used to specify the linear mapping to color
51 // theta and phi represent the camera position angles around
52 // the perimeter
53 // camera always look at the center of the xyz,
54 // camera's up will always be positive or zero
55 // in y (depending on phi)
56 // z represents distance from the center, setting this to zero will
57 // place the camera so that it can see all particles
58 void coprocessorcreateimage(int timestep, double time, char* filename_base, int n, double* xyz,
59  double* bounds, double r, double* attr, double min, double max, double theta, double phi,
60  double z);
61
62 void coprocessorfinalize();
63
64 #ifdef __cplusplus
65 } /* extern "C" */
66 #endif
67
68 #endif /* ParticleAdaptor_h */
void coprocessorinitialize(void *handle)
void coprocessorcreateimage(int timestep, double time, char *filename_base, int n, double *xyz, double *bounds, double r, double *attr, double min, double max, double theta, double phi, double z)
