This page is applicable to ParaView Catalyst implementation introduced in ParaView 5.9.
Starting with ParaView 5.9, ParaView distribution provides an implementation of the Catalyst API. This implementation is now referred to as ParaView-Catalyst. Thus, it an implementation of the Catalyst In Situ API that uses ParaView for data processing and rendering.
The Catalyst in situ API comprises for 3 main function calls that are used to pass data and control over to the Catalyst implementation from a computational simulation codes: catalyst_initialize, catalyst_execute, and catalyst_finalize. Each of these functions is passed a Conduit Node object. Conduit Node provides a flexible mechanism for describing hierarchical in-core scientific data. Since Conduit Node is simply a light-weight container, we need to define the conventions used to communicate relevant data in each of the Catalyst API calls. Such conventions are collectively referred to as the Blueprint. Each Catalyst API implementation can develop its own blueprint. ParaView-Catalyst, the Catalyst API implementation provided by ParaView, also defines its blueprint called the ParaView-Catalyst Blueprint. This page documents this blueprint.
A blueprint often includes several protocols, each defining the conventions for a specific use-case. Since there are three main Catalyst API functions, the blueprint currently defines three protocols, one for each of the Catalyst API functions.
catalyst_initialize; these include things like ParaView Python scripts to load.catalyst_execute and includes information about Catalyst channels i.e. ports on which data is made available to in situ processing as well as the actual data from the simulation.catalyst_finalize; currently, this is empty.In each of the Catalyst API calls, ParaView looks for a top-level node named 'catalyst'. The expected children vary based on the protocol described in the following sub-sections.
These top-level protocols use other internal protocols e.g. 'channel'.
Currently, 'initialize' protocol defines how to pass scripts to load for analysis.
Additionally, one can provide a list of pre-compiled pipelines to use.
In MPI-enabled builds, ParaView is by default initialized to use MPI_COMM_WORLD as the global communicator. A specific MPI communicator can be provided as follows:
MPI_Comm using MPI_Comm_c2f().Defines now to communicate data during each time-iteration.
time/timestep/cycle: this defines temporal information about the current invocation.
channels: channels are used to communicate simulation data. The channels node can have one or more children, each corresponding to a named channel. A channel represents a data-source in the analysis pipeline that is linked to the data being produced by the simulation code.
The 'channel' protocol is as follows:
Currently, this is empty.
Defines type and parameters for a hard-coded pipeline.
When 'type' is 'io', the following attributes are supported.
ts may be used to replace with timestep or t may be used to replace with time value. You can use printf style format specifiers e.g. %03t etc. The filename may be used to determine which supported writer to use for saving the data.
