1 # Distributed under the OSI-approved BSD 3-Clause License. See accompanying 2 # file Copyright.txt or https://cmake.org/licensing for details. 4 #[=======================================================================[.rst: 8 Find the native ZLIB includes and library.
13 This module defines :prop_tgt:`IMPORTED`
target ``ZLIB::ZLIB``,
if 19 This module defines the following variables:
23 ZLIB_INCLUDE_DIRS - where to find zlib.h, etc.
24 ZLIB_LIBRARIES - List of libraries when
using zlib.
25 ZLIB_FOUND - True
if zlib found.
27 ::
ZLIB_VERSION_STRING - The
version of zlib found (x.y.z)
28 ZLIB_VERSION_MAJOR - The major version of zlib
29 ZLIB_VERSION_MINOR - The minor version of zlib
30 ZLIB_VERSION_PATCH - The patch version of zlib
31 ZLIB_VERSION_TWEAK - The tweak version of zlib
33 Backward Compatibility
34 ^^^^^^^^^^^^^^^^^^^^^^
36 The following variable are provided for backward compatibility
40 ZLIB_MAJOR_VERSION - The major version of zlib
41 ZLIB_MINOR_VERSION - The minor version of zlib
42 ZLIB_PATCH_VERSION - The patch version of zlib
47 A user may set ``ZLIB_ROOT`` to a zlib installation root to tell this
49 #]=======================================================================] 53 # Search ZLIB_ROOT first
if it is
set.
55 set(_ZLIB_SEARCH_ROOT PATHS ${ZLIB_ROOT} NO_DEFAULT_PATH)
56 list(APPEND _ZLIB_SEARCHES _ZLIB_SEARCH_ROOT)
60 set(_ZLIB_x86
"(x86)")
61 set(_ZLIB_SEARCH_NORMAL
62 PATHS
"[HKEY_LOCAL_MACHINE\\SOFTWARE\\GnuWin32\\Zlib;InstallPath]" 63 "$ENV{ProgramFiles}/zlib" 64 "$ENV{ProgramFiles${_ZLIB_x86}}/zlib")
66 list(APPEND _ZLIB_SEARCHES _ZLIB_SEARCH_NORMAL)
68 set(ZLIB_NAMES z zlib zdll zlib1)
69 set(ZLIB_NAMES_DEBUG zlibd zlibd1)
71 # Try each search configuration. 72 foreach(search ${_ZLIB_SEARCHES})
73 find_path(ZLIB_INCLUDE_DIR NAMES zlib.h ${${search}} PATH_SUFFIXES include)
76 # Allow ZLIB_LIBRARY to be set manually, as the location of the zlib library 78 foreach(search ${_ZLIB_SEARCHES})
79 find_library(ZLIB_LIBRARY_RELEASE NAMES ${ZLIB_NAMES} NAMES_PER_DIR ${${search}} PATH_SUFFIXES lib)
80 find_library(ZLIB_LIBRARY_DEBUG NAMES ${ZLIB_NAMES_DEBUG} NAMES_PER_DIR ${${search}} PATH_SUFFIXES lib)
83 include(SelectLibraryConfigurations)
84 select_library_configurations(ZLIB)
88 unset(ZLIB_NAMES_DEBUG)
90 mark_as_advanced(ZLIB_INCLUDE_DIR)
92 if(ZLIB_INCLUDE_DIR AND EXISTS "${ZLIB_INCLUDE_DIR}/zlib.h
") 93 file(STRINGS "${ZLIB_INCLUDE_DIR}/zlib.h
" ZLIB_H REGEX "^#define ZLIB_VERSION \
95 string(REGEX REPLACE
"^.*ZLIB_VERSION \"([0-9]+).*$" "\\1" ZLIB_VERSION_MAJOR
"${ZLIB_H}")
96 string(REGEX REPLACE
"^.*ZLIB_VERSION \"[0-9]+\\.([0-9]+).*$" "\\1" ZLIB_VERSION_MINOR
"${ZLIB_H}")
97 string(REGEX REPLACE
"^.*ZLIB_VERSION \"[0-9]+\\.[0-9]+\\.([0-9]+).*$" "\\1" ZLIB_VERSION_PATCH
"${ZLIB_H}")
98 set(ZLIB_VERSION_STRING
"${ZLIB_VERSION_MAJOR}.${ZLIB_VERSION_MINOR}.${ZLIB_VERSION_PATCH}")
100 # only append a TWEAK version
if it exists:
101 set(ZLIB_VERSION_TWEAK
102 if(
"${ZLIB_H}" MATCHES
"ZLIB_VERSION \"[0-9]+\\.[0-9]+\\.[0-9]+\\.([0-9]+)")
103 set(ZLIB_VERSION_TWEAK
"${CMAKE_MATCH_1}")
104 string(APPEND ZLIB_VERSION_STRING
".${ZLIB_VERSION_TWEAK}")
107 set(ZLIB_MAJOR_VERSION "${ZLIB_VERSION_MAJOR}
") 108 set(ZLIB_MINOR_VERSION "${ZLIB_VERSION_MINOR}
") 109 set(ZLIB_PATCH_VERSION "${ZLIB_VERSION_PATCH}
") 112 include(FindPackageHandleStandardArgs) 113 FIND_PACKAGE_HANDLE_STANDARD_ARGS(ZLIB REQUIRED_VARS ZLIB_LIBRARY ZLIB_INCLUDE_DIR 114 VERSION_VAR ZLIB_VERSION_STRING) 117 set(ZLIB_INCLUDE_DIRS ${ZLIB_INCLUDE_DIR}) 119 if(NOT ZLIB_LIBRARIES) 120 set(ZLIB_LIBRARIES ${ZLIB_LIBRARY}) 123 if(NOT TARGET ZLIB::ZLIB) 124 add_library(ZLIB::ZLIB UNKNOWN IMPORTED) 125 set_target_properties(ZLIB::ZLIB PROPERTIES 126 INTERFACE_INCLUDE_DIRECTORIES "${ZLIB_INCLUDE_DIRS}
") 128 if(ZLIB_LIBRARY_RELEASE) 129 set_property(TARGET ZLIB::ZLIB APPEND PROPERTY 130 IMPORTED_CONFIGURATIONS RELEASE) 131 set_target_properties(ZLIB::ZLIB PROPERTIES 132 IMPORTED_LOCATION_RELEASE "${ZLIB_LIBRARY_RELEASE}
") 135 if(ZLIB_LIBRARY_DEBUG) 136 set_property(TARGET ZLIB::ZLIB APPEND PROPERTY 137 IMPORTED_CONFIGURATIONS DEBUG) 138 set_target_properties(ZLIB::ZLIB PROPERTIES 139 IMPORTED_LOCATION_DEBUG "${ZLIB_LIBRARY_DEBUG}
") 142 if(NOT ZLIB_LIBRARY_RELEASE AND NOT ZLIB_LIBRARY_DEBUG) 143 set_property(TARGET ZLIB::ZLIB APPEND PROPERTY 144 IMPORTED_LOCATION "${ZLIB_LIBRARY}
") 148 boost::graph_traits< vtkGraph *>::vertex_descriptor target(boost::graph_traits< vtkGraph *>::edge_descriptor e, vtkGraph *)
