1 # - Try to find PEGTL lib 3 # This module supports requiring a minimum version, e.g. you can do 4 # find_package(PEGTL 3.1.2) 5 # to require version 3.1.2 or newer of PEGTL. 7 # Once done this will define 9 # PEGTL_FOUND - system has eigen lib with correct version 10 # PEGTL_INCLUDE_DIRS - the eigen include directory 11 # PEGTL_VERSION - eigen version 13 # And the following imported target: 17 # Copyright (c) 2006, 2007 Montel Laurent, <montel@kde.org> 18 # Copyright (c) 2008, 2009 Gael Guennebaud, <g.gael@free.fr> 19 # Copyright (c) 2009 Benoit Jacob <jacob.benoit.1@gmail.com> 20 # Redistribution and use is allowed according to the terms of the 2-clause BSD license. 22 find_path(PEGTL_INCLUDE_DIR
25 DOC
"Path to PEGTL headers")
26 mark_as_advanced(PEGTL_INCLUDE_DIR)
28 if (PEGTL_INCLUDE_DIR)
29 file(STRINGS
"${PEGTL_INCLUDE_DIR}/pegtl/version.hpp" _pegtl_version_header
30 REGEX
"TAO_PEGTL_VERSION")
31 string(REGEX MATCH
"define[ \t]+TAO_PEGTL_VERSION[ \t]+\"([0-9.]+)\"" _pegtl_version_match
"${_pegtl_version_header}")
32 set(PEGTL_VERSION
"${CMAKE_MATCH_1}")
33 unset(_pegtl_version_header)
34 unset(_pegtl_version_match)
37 include(FindPackageHandleStandardArgs)
38 find_package_handle_standard_args(PEGTL
39 REQUIRED_VARS PEGTL_INCLUDE_DIR
40 VERSION_VAR PEGTL_VERSION)
43 set(PEGTL_INCLUDE_DIRS "${PEGTL_INCLUDE_DIR}
") 44 if (NOT TARGET PEGTL::PEGTL) 45 add_library(PEGTL::PEGTL INTERFACE IMPORTED) 46 set_target_properties(PEGTL::PEGTL PROPERTIES 47 INTERFACE_INCLUDE_DIRECTORIES "${PEGTL_INCLUDE_DIR}
