1 # Distributed under the OSI-approved BSD 3-Clause License. See accompanying 2 # file Copyright.txt or https://cmake.org/licensing for details. 4 #[=======================================================================[.rst: 8 Find libarchive library and headers.
9 Libarchive is multi-format archive and compression library.
11 The module defines the following variables:
15 LibArchive_FOUND -
true if libarchive was found
16 LibArchive_INCLUDE_DIRS - include search path
17 LibArchive_LIBRARIES - libraries to link
19 LibArchive::LibArchive -
target for linking against libarchive
20 #]=======================================================================] 22 find_path(LibArchive_INCLUDE_DIR
26 "[HKEY_LOCAL_MACHINE\\SOFTWARE\\GnuWin32\\LibArchive;InstallPath]/include" 27 DOC
"libarchive include directory")
28 mark_as_advanced(LibArchive_INCLUDE_DIR)
30 find_library(LibArchive_LIBRARY
34 "[HKEY_LOCAL_MACHINE\\SOFTWARE\\GnuWin32\\LibArchive;InstallPath]/lib" 35 DOC
"libarchive library")
36 mark_as_advanced(LibArchive_LIBRARY)
38 # Extract the version number from the header. 39 if(LibArchive_INCLUDE_DIR AND EXISTS
"${LibArchive_INCLUDE_DIR}/archive.h")
40 # The version string appears in one of three known formats in the header: 41 # #define ARCHIVE_LIBRARY_VERSION "libarchive 2.4.12" 42 # #define ARCHIVE_VERSION_STRING "libarchive 2.8.4" 43 # #define ARCHIVE_VERSION_ONLY_STRING "3.2.0" 45 set(_LibArchive_VERSION_REGEX
"^#define[ \t]+ARCHIVE[_A-Z]+VERSION[_A-Z]*[ \t]+\"(libarchive +)?([0-9]+)\\.([0-9]+)\\.([0-9]+)[^\"]*\".*$")
46 file(STRINGS
"${LibArchive_INCLUDE_DIR}/archive.h" _LibArchive_VERSION_STRING LIMIT_COUNT 1 REGEX
"${_LibArchive_VERSION_REGEX}")
47 if(_LibArchive_VERSION_STRING)
48 string(REGEX REPLACE
"${_LibArchive_VERSION_REGEX}" "\\2.\\3.\\4" LibArchive_VERSION
"${_LibArchive_VERSION_STRING}")
50 unset(_LibArchive_VERSION_REGEX)
51 unset(_LibArchive_VERSION_STRING)
54 include(FindPackageHandleStandardArgs)
55 find_package_handle_standard_args(LibArchive
56 REQUIRED_VARS LibArchive_LIBRARY LibArchive_INCLUDE_DIR
57 VERSION_VAR LibArchive_VERSION
59 unset(LIBARCHIVE_FOUND)
62 set(LibArchive_LIBRARIES "${LibArchive_LIBRRAY}
") 63 set(LibArchive_INCLUDE_DIRS "${LibArchive_INCLUDE_DIR}
") 65 if (NOT TARGET LibArchive::LibArchive) 66 add_library(LibArchive::LibArchive UNKNOWN IMPORTED) 67 set_target_properties(LibArchive::LibArchive PROPERTIES 68 IMPORTED_LOCATION "${LibArchive_LIBRARY}
" 69 INTERFACE_INCLUDE_DIRECTORIES "${LibArchive_INCLUDE_DIR}
