1 # Distributed under the OSI-approved BSD 3-Clause License. See accompanying 2 # file Copyright.txt or https://cmake.org/licensing for details. 4 #[=======================================================================[.rst: 8 Find the JPEG library (libjpeg)
13 This module defines the following :prop_tgt:`IMPORTED` targets:
16 The JPEG library,
if found.
21 This module will
set the following variables in your project:
24 If
false,
do not
try to use JPEG.
26 where to find jpeglib.h, etc.
28 the libraries needed to use JPEG.
30 the
version of the JPEG library found
35 The following cache variables may also be
set:
38 where to find jpeglib.h, etc.
39 ``JPEG_LIBRARY_RELEASE``
40 where to find the JPEG library (optimized).
41 ``JPEG_LIBRARY_DEBUG``
42 where to find the JPEG library (debug).
48 where to find jpeglib.h, etc. (same as JPEG_INCLUDE_DIRS)
50 where to find the JPEG library.
51 #]=======================================================================]
53 find_path(JPEG_INCLUDE_DIR jpeglib.h)
55 set(jpeg_names ${JPEG_NAMES} jpeg jpeg-
static libjpeg libjpeg-
static)
56 foreach(name ${jpeg_names})
57 list(APPEND jpeg_names_debug
"${name}d")
61 find_library(JPEG_LIBRARY_RELEASE NAMES ${jpeg_names})
62 find_library(JPEG_LIBRARY_DEBUG NAMES ${jpeg_names_debug})
63 include(SelectLibraryConfigurations)
64 select_library_configurations(JPEG)
65 mark_as_advanced(JPEG_LIBRARY_RELEASE JPEG_LIBRARY_DEBUG)
68 unset(jpeg_names_debug)
70 if(JPEG_INCLUDE_DIR AND EXISTS "${JPEG_INCLUDE_DIR}/jpeglib.h
") 71 file(GLOB _JPEG_CONFIG_HEADERS "${JPEG_INCLUDE_DIR}/jconfig*.h
") 72 list(INSERT _JPEG_CONFIG_HEADERS 0 73 "${JPEG_INCLUDE_DIR}/jpeglib.h
") 74 foreach (_JPEG_CONFIG_HEADER IN LISTS _JPEG_CONFIG_HEADERS) 75 file(STRINGS "${_JPEG_CONFIG_HEADER}
" 78 if (NOT jpeg_lib_version) 83 "\\1
" JPEG_VERSION "${jpeg_lib_version}
") 86 unset(jpeg_lib_version) 87 unset(_JPEG_CONFIG_HEADER) 88 unset(_JPEG_CONFIG_HEADERS) 91 include(FindPackageHandleStandardArgs) 92 find_package_handle_standard_args(JPEG 93 REQUIRED_VARS JPEG_LIBRARY JPEG_INCLUDE_DIR 94 VERSION_VAR JPEG_VERSION) 97 set(JPEG_LIBRARIES ${JPEG_LIBRARY}) 98 set(JPEG_INCLUDE_DIRS "${JPEG_INCLUDE_DIR}
") 100 if(NOT TARGET JPEG::JPEG) 101 add_library(JPEG::JPEG UNKNOWN IMPORTED) 102 if(JPEG_INCLUDE_DIRS) 103 set_target_properties(JPEG::JPEG PROPERTIES 104 INTERFACE_INCLUDE_DIRECTORIES "${JPEG_INCLUDE_DIRS}
") 106 if(EXISTS "${JPEG_LIBRARY}
") 107 set_target_properties(JPEG::JPEG PROPERTIES 108 IMPORTED_LINK_INTERFACE_LANGUAGES "C
" 109 IMPORTED_LOCATION "${JPEG_LIBRARY}
") 111 if(EXISTS "${JPEG_LIBRARY_RELEASE}
") 112 set_property(TARGET JPEG::JPEG APPEND PROPERTY 113 IMPORTED_CONFIGURATIONS RELEASE) 114 set_target_properties(JPEG::JPEG PROPERTIES 115 IMPORTED_LINK_INTERFACE_LANGUAGES_RELEASE "C
" 116 IMPORTED_LOCATION_RELEASE "${JPEG_LIBRARY_RELEASE}
") 118 if(EXISTS "${JPEG_LIBRARY_DEBUG}
") 119 set_property(TARGET JPEG::JPEG APPEND PROPERTY 120 IMPORTED_CONFIGURATIONS DEBUG) 121 set_target_properties(JPEG::JPEG PROPERTIES 122 IMPORTED_LINK_INTERFACE_LANGUAGES_DEBUG "C
" 123 IMPORTED_LOCATION_DEBUG "${JPEG_LIBRARY_DEBUG}
") 128 mark_as_advanced(JPEG_LIBRARY JPEG_INCLUDE_DIR)
