1 # Install script for directory: /home/paraview/Clients/InSitu 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47 "/home/paraview/Clients/InSitu/vtkInSituPipeline.h" 48 "/home/paraview/Clients/InSitu/vtkInSituPipelineIO.h" 49 "/home/paraview/Clients/InSitu/vtkInSituPipelinePython.h" 50 "/home/paraview/Clients/InSitu/vtkInSituInitializationHelper.h" 51 "/home/paraview/build/Clients/InSitu/vtkPVInSituModule.h" 55 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 56 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkPVInSitu-hierarchy.txt
" FILES "/home/paraview/build/lib64/
vtk/hierarchy/ParaView/vtkPVInSitu-hierarchy.txt
") 59 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 61 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVInSitu-pv5.9.so.5.9
" 62 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVInSitu-pv5.9.so.1
" 64 if(EXISTS "${file}
" AND 65 NOT IS_SYMLINK "${file}
") 68 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 71 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 72 "/home/paraview/build/lib64/libvtkPVInSitu-pv5.9.so.5.9
" 73 "/home/paraview/build/lib64/libvtkPVInSitu-pv5.9.so.1
" 76 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVInSitu-pv5.9.so.5.9
" 77 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVInSitu-pv5.9.so.1
" 79 if(EXISTS "${file}
" AND 80 NOT IS_SYMLINK "${file}
") 83 OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:
" 84 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 85 if(CMAKE_INSTALL_DO_STRIP) 86 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 92 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 93 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVInSitu-pv5.9.so
" AND 94 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVInSitu-pv5.9.so
") 96 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVInSitu-pv5.9.so
" 97 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 99 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkPVInSitu-pv5.9.so
") 100 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVInSitu-pv5.9.so
" AND 101 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVInSitu-pv5.9.so
") 103 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVInSitu-pv5.9.so
" 104 OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:
" 105 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 106 if(CMAKE_INSTALL_DO_STRIP) 107 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVInSitu-pv5.9.so
") 112 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 113 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so.2
" AND 114 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so.2
") 116 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so.2
" 117 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 119 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libcatalyst.so.2
") 120 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so.2
" AND 121 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so.2
") 123 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so.2
" 124 OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:
" 125 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 126 if(CMAKE_INSTALL_DO_STRIP) 127 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so.2
") 132 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 133 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so
" AND 134 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so
") 136 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so
" 137 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 139 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
") 140 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so
" AND 141 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so
") 143 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so
" 144 OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:
" 145 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 146 if(CMAKE_INSTALL_DO_STRIP) 147 execute_process(COMMAND "/usr/bin/strip
") 152 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xUnspecifiedx
" OR NOT CMAKE_INSTALL_COMPONENT) 153 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so.2
" AND 154 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so.2
") 156 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so.2
" 157 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 159 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
") 160 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so.2
" AND 161 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so.2
") 163 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so.2
" 164 OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:
" 165 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 166 if(CMAKE_INSTALL_DO_STRIP) 167 execute_process(COMMAND "/usr/bin/strip
") 172 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 173 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so
" AND 174 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so
") 176 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so
" 177 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 179 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
") 180 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so
" AND 181 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so
") 183 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libcatalyst.so
" 184 OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:
" 185 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 186 if(CMAKE_INSTALL_DO_STRIP) 187 execute_process(COMMAND "/usr/bin/strip
