1 # Install script for directory: /home/paraview/Clients/CommandLineExecutables
45 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE FILE RENAME "paraview.conf" FILES "/home/paraview/build/Clients/CommandLineExecutables/CMakeFiles/paraview.conf.install")
47 endif()
48
49 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
50  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver" AND
51  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver")
52  file(RPATH_CHECK
53  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver"
54  RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib")
55  endif()
56  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE EXECUTABLE FILES "/home/paraview/build/bin/pvserver")
57  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver" AND
58  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver")
59  file(RPATH_CHANGE
60  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver"
61  OLD_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib:"
62  NEW_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib")
63  if(CMAKE_INSTALL_DO_STRIP)
64  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver")
65  endif()
66  endif()
67 endif()
68
69 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
70  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver" AND
71  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver")
72  file(RPATH_CHECK
73  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver"
74  RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib")
75  endif()
76  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE EXECUTABLE FILES "/home/paraview/build/bin/pvdataserver")
77  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver" AND
78  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver")
79  file(RPATH_CHANGE
80  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver"
81  OLD_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib:"
82  NEW_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib")
83  if(CMAKE_INSTALL_DO_STRIP)
84  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver")
85  endif()
86  endif()
87 endif()
88
89 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
90  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver" AND
91  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver")
92  file(RPATH_CHECK
93  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver"
94  RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib")
95  endif()
96  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE EXECUTABLE FILES "/home/paraview/build/bin/pvrenderserver")
97  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver" AND
98  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver")
99  file(RPATH_CHANGE
100  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver"
101  OLD_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib:"
102  NEW_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib")
103  if(CMAKE_INSTALL_DO_STRIP)
104  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver")
105  endif()
106  endif()
107 endif()
108
109 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
110  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch" AND
111  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch")
112  file(RPATH_CHECK
113  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch"
114  RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib")
115  endif()
116  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE EXECUTABLE FILES "/home/paraview/build/bin/pvbatch")
117  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch" AND
118  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch")
119  file(RPATH_CHANGE
120  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch"
121  OLD_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib:"
122  NEW_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib")
123  if(CMAKE_INSTALL_DO_STRIP)
124  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch")
125  endif()
126  endif()
127 endif()
128
129 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
130  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython" AND
131  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython")
132  file(RPATH_CHECK
133  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython"
134  RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib")
135  endif()
136  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE EXECUTABLE FILES "/home/paraview/build/bin/pvpython")
137  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython" AND
138  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython")
139  file(RPATH_CHANGE
140  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython"
141  OLD_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib:"
142  NEW_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib")
143  if(CMAKE_INSTALL_DO_STRIP)
144  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython")
145  endif()
146  endif()
147 endif()
148
149 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
150  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE PROGRAM FILES "/home/paraview/build/bin/paraview-config")
151 endif()
152
153 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
154  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.9/ParaViewTools-targets.cmake")
155  file(DIFFERENT EXPORT_FILE_CHANGED FILES
156  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.9/ParaViewTools-targets.cmake"
157  "/home/paraview/build/Clients/CommandLineExecutables/CMakeFiles/Export/lib64/cmake/paraview-5.9/ParaViewTools-targets.cmake")
158  if(EXPORT_FILE_CHANGED)
159  file(GLOB OLD_CONFIG_FILES "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.9/ParaViewTools-targets-*.cmake")
160  if(OLD_CONFIG_FILES)
161  message(STATUS "Old export file \"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.9/ParaViewTools-targets.cmake\" will be replaced. Removing files [${OLD_CONFIG_FILES}].")
162  file(REMOVE ${OLD_CONFIG_FILES})
163  endif()
164  endif()
165  endif()
166  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.9" TYPE FILE FILES "/home/paraview/build/Clients/CommandLineExecutables/CMakeFiles/Export/lib64/cmake/paraview-5.9/ParaViewTools-targets.cmake")
167  if("${CMAKE_INSTALL_CONFIG_NAME}" MATCHES "^([Dd][Ee][Bb][Uu][Gg])$")
168  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.9" TYPE FILE FILES "/home/paraview/build/Clients/CommandLineExecutables/CMakeFiles/Export/lib64/cmake/paraview-5.9/ParaViewTools-targets-debug.cmake")
169  endif()
170 endif()
171
