1 # Install script for directory: /home/paraview/Clients/Catalyst 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47 "/home/paraview/build/Clients/Catalyst/vtkCPConfig.h" 48 "/home/paraview/build/Clients/Catalyst/FortranAdaptorAPIMangling.h" 49 "/home/paraview/Clients/Catalyst/CAdaptorAPI.h" 50 "/home/paraview/Clients/Catalyst/vtkCPAdaptorAPI.h" 51 "/home/paraview/Clients/Catalyst/vtkCPCxxHelper.h" 52 "/home/paraview/Clients/Catalyst/vtkCPDataDescription.h" 53 "/home/paraview/Clients/Catalyst/vtkCPInputDataDescription.h" 54 "/home/paraview/Clients/Catalyst/vtkCPPipeline.h" 55 "/home/paraview/Clients/Catalyst/vtkCPProcessor.h" 56 "/home/paraview/Clients/Catalyst/vtkCPXMLPWriterPipeline.h" 57 "/home/paraview/Clients/Catalyst/FortranAdaptorAPI.h" 58 "/home/paraview/build/Clients/Catalyst/vtkPVCatalystModule.h" 62 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 63 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkPVCatalyst-hierarchy.txt
" FILES "/home/paraview/build/lib64/
vtk/hierarchy/ParaView/vtkPVCatalyst-hierarchy.txt
") 66 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 68 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.9.so.5.9
" 69 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.9.so.1
" 71 if(EXISTS "${file}
" AND 72 NOT IS_SYMLINK "${file}
") 75 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 78 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 79 "/home/paraview/build/lib64/libvtkPVCatalyst-pv5.9.so.5.9
" 80 "/home/paraview/build/lib64/libvtkPVCatalyst-pv5.9.so.1
" 83 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.9.so.5.9
" 84 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.9.so.1
" 86 if(EXISTS "${file}
" AND 87 NOT IS_SYMLINK "${file}
") 90 OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:
" 91 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 92 if(CMAKE_INSTALL_DO_STRIP) 93 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 99 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 100 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.9.so
" AND 101 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.9.so
") 103 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.9.so
" 104 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 106 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkPVCatalyst-pv5.9.so
") 107 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.9.so
" AND 108 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.9.so
") 110 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.9.so
" 111 OLD_RPATH "/home/paraview/build/lib64:/usr/lib64/openmpi/lib:
" 112 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 113 if(CMAKE_INSTALL_DO_STRIP) 114 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.9.so
