1 set(CMAKE_Fortran_COMPILER
"/usr/bin/f95")
2 set(CMAKE_Fortran_COMPILER_ARG1
3 set(CMAKE_Fortran_COMPILER_ID
"GNU")
4 set(CMAKE_Fortran_COMPILER_VERSION
"10.2.1")
5 set(CMAKE_Fortran_COMPILER_WRAPPER
6 set(CMAKE_Fortran_PLATFORM_ID
7 set(CMAKE_Fortran_SIMULATE_ID
8 set(CMAKE_Fortran_SIMULATE_VERSION
13 set(CMAKE_AR
"/usr/bin/ar")
14 set(CMAKE_Fortran_COMPILER_AR
"/usr/bin/gcc-ar")
15 set(CMAKE_RANLIB
"/usr/bin/ranlib")
16 set(CMAKE_Fortran_COMPILER_RANLIB
"/usr/bin/gcc-ranlib")
17 set(CMAKE_COMPILER_IS_GNUG77 1)
18 set(CMAKE_Fortran_COMPILER_LOADED 1)
19 set(CMAKE_Fortran_COMPILER_WORKS TRUE)
20 set(CMAKE_Fortran_ABI_COMPILED TRUE)
21 set(CMAKE_COMPILER_IS_MINGW )
22 set(CMAKE_COMPILER_IS_CYGWIN )
23 if(CMAKE_COMPILER_IS_CYGWIN)
28 set(CMAKE_Fortran_COMPILER_ENV_VAR "FC")
30 set(CMAKE_Fortran_COMPILER_SUPPORTS_F90 1)
32 if(CMAKE_COMPILER_IS_MINGW)
35 set(CMAKE_Fortran_COMPILER_ID_RUN 1)
36 set(CMAKE_Fortran_SOURCE_FILE_EXTENSIONS f;F;fpp;FPP;f77;F77;f90;F90;for;For;FOR;f95;F95)
37 set(CMAKE_Fortran_IGNORE_EXTENSIONS h;H;o;O;obj;OBJ;def;DEF;rc;RC)
38 set(CMAKE_Fortran_LINKER_PREFERENCE 20)
40 set(CMAKE_Fortran_OUTPUT_EXTENSION .o)
42 set(CMAKE_Fortran_OUTPUT_EXTENSION .obj)
45 # Save compiler ABI information. 46 set(CMAKE_Fortran_SIZEOF_DATA_PTR
"8")
47 set(CMAKE_Fortran_COMPILER_ABI
48 set(CMAKE_Fortran_LIBRARY_ARCHITECTURE
50 if(CMAKE_Fortran_SIZEOF_DATA_PTR AND NOT CMAKE_SIZEOF_VOID_P)
51 set(CMAKE_SIZEOF_VOID_P
"${CMAKE_Fortran_SIZEOF_DATA_PTR}")
54 if(CMAKE_Fortran_COMPILER_ABI)
55 set(CMAKE_INTERNAL_PLATFORM_ABI
"${CMAKE_Fortran_COMPILER_ABI}")
58 if(CMAKE_Fortran_LIBRARY_ARCHITECTURE)
59 set(CMAKE_LIBRARY_ARCHITECTURE
66 set(CMAKE_Fortran_IMPLICIT_INCLUDE_DIRECTORIES
"/usr/lib/gcc/x86_64-redhat-linux/10/finclude;/usr/lib/gcc/x86_64-redhat-linux/10/include;/usr/local/include;/usr/include")
67 set(CMAKE_Fortran_IMPLICIT_LINK_LIBRARIES
"gfortran;m;gcc_s;gcc;quadmath;m;gcc_s;gcc;c;gcc_s;gcc")
68 set(CMAKE_Fortran_IMPLICIT_LINK_DIRECTORIES
"/usr/lib/gcc/x86_64-redhat-linux/10;/usr/lib64;/lib64;/usr/lib")
69 set(CMAKE_Fortran_IMPLICIT_LINK_FRAMEWORK_DIRECTORIES
