1 # Install script for directory: /home/paraview/.gitlab/cmake/share/cmake-3.19/Modules/FortranCInterface
40 if(CMAKE_INSTALL_COMPONENT)
41  set(CMAKE_INSTALL_MANIFEST "install_manifest_${CMAKE_INSTALL_COMPONENT}.txt")
42 else()
43  set(CMAKE_INSTALL_MANIFEST "install_manifest.txt")
44 endif()
45
46 string(REPLACE ";" "\n" CMAKE_INSTALL_MANIFEST_CONTENT
47  "${CMAKE_INSTALL_MANIFEST_FILES}")
48 file(WRITE "/home/paraview/build/CMakeFiles/FortranCInterface/${CMAKE_INSTALL_MANIFEST}"
49  "${CMAKE_INSTALL_MANIFEST_CONTENT}")
