3 if(
4 message(FATAL_ERROR
"CMake >= 2.6.0 required")
15 # Protect against multiple inclusion, which would fail when already imported targets are added once more.
17 set(_targetsNotDefined)
19 foreach(_expectedTarget VTK::vtkCommonCorePython VTK::vtkParallelMPI4PyPython VTK::vtkCommonMathPython VTK::vtkCommonTransformsPython VTK::vtkCommonDataModelPython VTK::vtkCommonExecutionModelPython VTK::vtkIOVPICPython VTK::vtkIOXMLParserPython VTK::vtkIOXMLPython VTK::vtkIOParallelXMLPython VTK::vtkIOCorePython VTK::vtkIOPLYPython VTK::vtkIOLegacyPython VTK::vtkIOGeometryPython VTK::vtkImagingCorePython VTK::vtkIOImagePython VTK::vtkIOParallelPython VTK::vtkIOMPIImagePython VTK::vtkIOInfovisPython VTK::vtkCommonColorPython VTK::vtkImagingSourcesPython VTK::vtkCommonMiscPython VTK::vtkFiltersCorePython VTK::vtkRenderingCorePython VTK::vtkRenderingFreeTypePython VTK::vtkInfovisCorePython VTK::vtkIOAsynchronousPython VTK::vtkRenderingVolumePython VTK::vtkImagingHybridPython VTK::vtkFiltersPythonPython VTK::vtkFiltersProgrammablePython VTK::vtkFiltersGeneralPython VTK::vtkFiltersModelingPython VTK::vtkFiltersPointsPython VTK::vtkFiltersVerdictPython VTK::vtkParallelCorePython VTK::vtkFiltersParallelVerdictPython VTK::vtkFiltersStatisticsPython VTK::vtkFiltersParallelStatisticsPython VTK::vtkCommonSystemPython VTK::vtkFiltersGeometryPython VTK::vtkFiltersExtractionPython VTK::vtkFiltersHybridPython VTK::vtkFiltersSourcesPython VTK::vtkFiltersTexturePython VTK::vtkFiltersParallelPython VTK::vtkParallelMPIPython VTK::vtkFiltersParallelGeometryPython VTK::vtkCommonComputationalGeometryPython VTK::vtkFiltersFlowPathsPython VTK::vtkFiltersParallelFlowPathsPython VTK::vtkFiltersParallelDIY2Python VTK::vtkImagingGeneralPython VTK::vtkFiltersHyperTreePython VTK::vtkFiltersGenericPython VTK::vtkFiltersAMRPython VTK::vtkFiltersParallelMPIPython VTK::vtkDomainsChemistryPython VTK::vtkImagingFourierPython VTK::vtkpythonmodules)
20 list(APPEND _expectedTargets ${_expectedTarget})
21 if(NOT TARGET ${_expectedTarget})
22 list(APPEND _targetsNotDefined ${_expectedTarget})
24 if(TARGET ${_expectedTarget})
25 list(APPEND _targetsDefined ${_expectedTarget})
28 if("${_targetsDefined}
") 29 unset(_targetsDefined) 30 unset(_targetsNotDefined) 31 unset(_expectedTargets) 32 set(CMAKE_IMPORT_FILE_VERSION) 36 if(NOT "${_targetsDefined}
" STREQUAL "") 37 message(FATAL_ERROR "Some (but not all) targets in
this export
") 39 unset(_targetsDefined) 40 unset(_targetsNotDefined) 41 unset(_expectedTargets) 44 # Compute the installation prefix relative to this file. 45 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}
" PATH) 46 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 47 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 48 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 49 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 50 if(_IMPORT_PREFIX STREQUAL "/
") 51 set(_IMPORT_PREFIX "") 54 # Create imported target VTK::vtkCommonCorePython 55 add_library(VTK::vtkCommonCorePython MODULE IMPORTED) 57 # Create imported target VTK::vtkParallelMPI4PyPython 58 add_library(VTK::vtkParallelMPI4PyPython MODULE IMPORTED) 60 # Create imported target VTK::vtkCommonMathPython 61 add_library(VTK::vtkCommonMathPython MODULE IMPORTED) 63 # Create imported target VTK::vtkCommonTransformsPython 64 add_library(VTK::vtkCommonTransformsPython MODULE IMPORTED) 66 # Create imported target VTK::vtkCommonDataModelPython 67 add_library(VTK::vtkCommonDataModelPython MODULE IMPORTED) 69 # Create imported target VTK::vtkCommonExecutionModelPython 70 add_library(VTK::vtkCommonExecutionModelPython MODULE IMPORTED) 72 # Create imported target VTK::vtkIOVPICPython 73 add_library(VTK::vtkIOVPICPython MODULE IMPORTED) 75 # Create imported target VTK::vtkIOXMLParserPython 76 add_library(VTK::vtkIOXMLParserPython MODULE IMPORTED) 78 # Create imported target VTK::vtkIOXMLPython 79 add_library(VTK::vtkIOXMLPython MODULE IMPORTED) 81 # Create imported target VTK::vtkIOParallelXMLPython 82 add_library(VTK::vtkIOParallelXMLPython MODULE IMPORTED) 84 # Create imported target VTK::vtkIOCorePython 85 add_library(VTK::vtkIOCorePython MODULE IMPORTED) 87 # Create imported target VTK::vtkIOPLYPython 88 add_library(VTK::vtkIOPLYPython MODULE IMPORTED) 90 # Create imported target VTK::vtkIOLegacyPython 91 add_library(VTK::vtkIOLegacyPython MODULE IMPORTED) 93 # Create imported target VTK::vtkIOGeometryPython 94 add_library(VTK::vtkIOGeometryPython MODULE IMPORTED) 96 # Create imported target VTK::vtkImagingCorePython 97 add_library(VTK::vtkImagingCorePython MODULE IMPORTED) 99 # Create imported target VTK::vtkIOImagePython 100 add_library(VTK::vtkIOImagePython MODULE IMPORTED) 102 # Create imported target VTK::vtkIOParallelPython 103 add_library(VTK::vtkIOParallelPython MODULE IMPORTED) 105 # Create imported target VTK::vtkIOMPIImagePython 106 add_library(VTK::vtkIOMPIImagePython MODULE IMPORTED) 108 # Create imported target VTK::vtkIOInfovisPython 109 add_library(VTK::vtkIOInfovisPython MODULE IMPORTED) 111 # Create imported target VTK::vtkCommonColorPython 112 add_library(VTK::vtkCommonColorPython MODULE IMPORTED) 114 # Create imported target VTK::vtkImagingSourcesPython 115 add_library(VTK::vtkImagingSourcesPython MODULE IMPORTED) 117 # Create imported target VTK::vtkCommonMiscPython 118 add_library(VTK::vtkCommonMiscPython MODULE IMPORTED) 120 # Create imported target VTK::vtkFiltersCorePython 121 add_library(VTK::vtkFiltersCorePython MODULE IMPORTED) 123 # Create imported target VTK::vtkRenderingCorePython 124 add_library(VTK::vtkRenderingCorePython MODULE IMPORTED) 126 # Create imported target VTK::vtkRenderingFreeTypePython 127 add_library(VTK::vtkRenderingFreeTypePython MODULE IMPORTED) 129 # Create imported target VTK::vtkInfovisCorePython 130 add_library(VTK::vtkInfovisCorePython MODULE IMPORTED) 132 # Create imported target VTK::vtkIOAsynchronousPython 133 add_library(VTK::vtkIOAsynchronousPython MODULE IMPORTED) 135 # Create imported target VTK::vtkRenderingVolumePython 136 add_library(VTK::vtkRenderingVolumePython MODULE IMPORTED) 138 # Create imported target VTK::vtkImagingHybridPython 139 add_library(VTK::vtkImagingHybridPython MODULE IMPORTED) 141 # Create imported target VTK::vtkFiltersPythonPython 142 add_library(VTK::vtkFiltersPythonPython MODULE IMPORTED) 144 # Create imported target VTK::vtkFiltersProgrammablePython 145 add_library(VTK::vtkFiltersProgrammablePython MODULE IMPORTED) 147 # Create imported target VTK::vtkFiltersGeneralPython 148 add_library(VTK::vtkFiltersGeneralPython MODULE IMPORTED) 150 # Create imported target VTK::vtkFiltersModelingPython 151 add_library(VTK::vtkFiltersModelingPython MODULE IMPORTED) 153 # Create imported target VTK::vtkFiltersPointsPython 154 add_library(VTK::vtkFiltersPointsPython MODULE IMPORTED) 156 # Create imported target VTK::vtkFiltersVerdictPython 157 add_library(VTK::vtkFiltersVerdictPython MODULE IMPORTED) 159 # Create imported target VTK::vtkParallelCorePython 160 add_library(VTK::vtkParallelCorePython MODULE IMPORTED) 162 # Create imported target VTK::vtkFiltersParallelVerdictPython 163 add_library(VTK::vtkFiltersParallelVerdictPython MODULE IMPORTED) 165 # Create imported target VTK::vtkFiltersStatisticsPython 166 add_library(VTK::vtkFiltersStatisticsPython MODULE IMPORTED) 168 # Create imported target VTK::vtkFiltersParallelStatisticsPython 169 add_library(VTK::vtkFiltersParallelStatisticsPython MODULE IMPORTED) 171 # Create imported target VTK::vtkCommonSystemPython 172 add_library(VTK::vtkCommonSystemPython MODULE IMPORTED) 174 # Create imported target VTK::vtkFiltersGeometryPython 175 add_library(VTK::vtkFiltersGeometryPython MODULE IMPORTED) 177 # Create imported target VTK::vtkFiltersExtractionPython 178 add_library(VTK::vtkFiltersExtractionPython MODULE IMPORTED) 180 # Create imported target VTK::vtkFiltersHybridPython 181 add_library(VTK::vtkFiltersHybridPython MODULE IMPORTED) 183 # Create imported target VTK::vtkFiltersSourcesPython 184 add_library(VTK::vtkFiltersSourcesPython MODULE IMPORTED) 186 # Create imported target VTK::vtkFiltersTexturePython 187 add_library(VTK::vtkFiltersTexturePython MODULE IMPORTED) 189 # Create imported target VTK::vtkFiltersParallelPython 190 add_library(VTK::vtkFiltersParallelPython MODULE IMPORTED) 192 # Create imported target VTK::vtkParallelMPIPython 193 add_library(VTK::vtkParallelMPIPython MODULE IMPORTED) 195 # Create imported target VTK::vtkFiltersParallelGeometryPython 196 add_library(VTK::vtkFiltersParallelGeometryPython MODULE IMPORTED) 198 # Create imported target VTK::vtkCommonComputationalGeometryPython 199 add_library(VTK::vtkCommonComputationalGeometryPython MODULE IMPORTED) 201 # Create imported target VTK::vtkFiltersFlowPathsPython 202 add_library(VTK::vtkFiltersFlowPathsPython MODULE IMPORTED) 204 # Create imported target VTK::vtkFiltersParallelFlowPathsPython 205 add_library(VTK::vtkFiltersParallelFlowPathsPython MODULE IMPORTED) 207 # Create imported target VTK::vtkFiltersParallelDIY2Python 208 add_library(VTK::vtkFiltersParallelDIY2Python MODULE IMPORTED) 210 # Create imported target VTK::vtkImagingGeneralPython 211 add_library(VTK::vtkImagingGeneralPython MODULE IMPORTED) 213 # Create imported target VTK::vtkFiltersHyperTreePython 214 add_library(VTK::vtkFiltersHyperTreePython MODULE IMPORTED) 216 # Create imported target VTK::vtkFiltersGenericPython 217 add_library(VTK::vtkFiltersGenericPython MODULE IMPORTED) 219 # Create imported target VTK::vtkFiltersAMRPython 220 add_library(VTK::vtkFiltersAMRPython MODULE IMPORTED) 222 # Create imported target VTK::vtkFiltersParallelMPIPython 223 add_library(VTK::vtkFiltersParallelMPIPython MODULE IMPORTED) 225 # Create imported target VTK::vtkDomainsChemistryPython 226 add_library(VTK::vtkDomainsChemistryPython MODULE IMPORTED) 228 # Create imported target VTK::vtkImagingFourierPython 229 add_library(VTK::vtkImagingFourierPython MODULE IMPORTED) 231 # Create imported target VTK::vtkpythonmodules 232 add_library(VTK::vtkpythonmodules INTERFACE IMPORTED) 234 if(CMAKE_VERSION VERSION_LESS 3.0.0) 235 message(FATAL_ERROR "This file relies
on consumers
using CMake 3.0.0 or greater.
") 238 # Load information for each installed configuration. 239 get_filename_component(_DIR "${CMAKE_CURRENT_LIST_FILE}
" PATH) 240 file(GLOB CONFIG_FILES "${_DIR}/VTKPython-targets-*.cmake
") 241 foreach(f ${CONFIG_FILES}) 245 # Cleanup temporary variables. 248 # Loop over all imported files and verify that they actually exist 249 foreach(target ${_IMPORT_CHECK_TARGETS} ) 250 foreach(file ${_IMPORT_CHECK_FILES_FOR_${target}} ) 251 if(NOT EXISTS "${file}
" ) 252 message(FATAL_ERROR "The imported
target \
"${target}\" references the file 254 but this file does not exist. Possible reasons include: 255 * The file was deleted, renamed, or moved to another location. 256 * An install or uninstall procedure did not complete successfully. 257 * The installation package was faulty and contained 258 \"${CMAKE_CURRENT_LIST_FILE}\" 259 but not all the files it references. 263 unset(_IMPORT_CHECK_FILES_FOR_${
target})
265 unset(_IMPORT_CHECK_TARGETS)
267 # This file does not depend on other imported targets which have 268 # been exported from the same project but in a separate export set. 270 # Commands beyond this point should not need to know the version. 271 set(CMAKE_IMPORT_FILE_VERSION)
